> Valve collision problem
thomasotten
post Jun 30 2018, 08:03 PM
I am having a bit of a problem with my latest 2 liter build. Basically, valves are colliding with pistons after warm up during break in. A valve got stuck and the pushrod actually fell off the rocker.
The heads were redon by RIMCO. After the problem happened, I pulled the heads, and there was clear indication of valve collision, and I had a valve stuck open. The head with a problem was sent back to RIMCO.
Reinstalled. What happened this time is the engine start up from cold, runs fine. But then I can hear the taping of collision again. The taping is accompanied by a chirping sound that sounds like something is dragging. I think it must be the valves dragging and closing too slow.
I have a deck height of .065.
This is essentially a stock build, stock camshaft, etc.
Any ideas? Is this perhaps a valve stem lubrication issue?
Replies(1 - 19)
thelogo
post Jun 30 2018, 09:58 PM
Group: Retired Members
QUOTE(thomasotten @ Jun 30 2018, 07:03 PM) *
I thought if the valve gets stuck or struck the engine instantly destroy s itself ?
euro911
post Jul 1 2018, 04:29 AM
Deck height at the top of the barrels is one thing, but it sounds like maybe the shop cut the shoulders (where the top of the barrels slip into the head(s) too deep (IMG:style_emoticons/default/unsure.gif)
You may need to install shims between the base of the barrels and the case, or get another pair of heads (IMG:style_emoticons/default/confused24.gif)
bdstone914
post Jul 1 2018, 07:35 AM
bdstone914
The first thought is what did Rimco do when building the heads. They have a poor reputation for quality work.
Is this a basically a stock build?
How much lift is on the cam, what size valves are you running ? Aluminum or steel pushrods ?
Maybe you need pistons with a valve relief ?
Deck height as measured is not a direct measurement of the clearance from an open valve to piston due the valve angle and diameter.
That distance can be measured using clay ( or other formable material ) on the top of the piston, turn the engine over by hand slowly. After removing the head you can slice the clay to see the minimum distance that the edge of the valve to piston.
Regarding valve to guide clearance, should be correct as the guides come out of the box. Were the guides checked and replaced if needed ?
Since Rimco had the heads twice and the problem persists I would be looking for a better place to identify the problem.
Or pull the heads, remove the valve springs and check for clearance. If you have worn guides the valve can deflect at the tip.
.065" desk height should be more than enough if all other things are correct.
I am not an engine expert but I did once sleep at a Holiday Inn Express.
thomasotten
post Jul 1 2018, 07:48 AM
Basically a stock build. But with 96mm
Pistons with valve relief.
So, one head was sent back to Rimco.
This problem is on the other head.
See photos. Definitely a stuck valve. Pushrod
Fell out of rocker as result.
thomasotten
post Jul 1 2018, 07:49 AM
Stuck intake valve
Bartlett 914
post Jul 1 2018, 08:20 AM
Once the valve is bent, it is going to stick. Maybe a result and not a cause.
Mark Henry
post Jul 1 2018, 08:31 AM
that's what I do!
Possible causes:
Guides not sized/reamed/honed correctly after install, guides tight, valves sticking. Since you are saying it happens after warm up this is suspect. If this is the issue if you remove the springs you should feel drag on the valve even cold. I agree bent valve, but they usually bend at the tulip, not the stem.
Done right the valve should have no drag or sticky spots, it should slip like it's running in butter.
Same vein, when driving the guides in the tool is leaving a burr at the top (spring side) of the guide, again this is not sized/reamed/honed correctly after install issue.
Cam gear off by one tooth.
Lifter sticking in bore, unlikely but possible.
Bad or broken spring, weak spring should only show up in higher RPM's
Chirping sound, a fast squeak-squeak-squeak can also be a head sealing issue but you should be able to see (head off) carbon tracing or if using head gaskets a definite damage to the gasket. In extreme cases this will cut right into the aluminum head like a cutting torch.
Mark Henry
post Jul 1 2018, 08:35 AM
that's what I do!
QUOTE(thomasotten @ Jul 1 2018, 09:49 AM) *
Stuck intake valve
I often see this when a seat is falling out.
Mark Henry
post Jul 1 2018, 09:30 AM
that's what I do!
QUOTE(Mark Henry @ Jul 1 2018, 10:35 AM) *
Stuck intake valve
Take the head off and look at that valve, if it is a seat it will be sitting cocked in it's bore. If it sits back down take the valve off and either knock the seat around a bit or heat it to 375-400 in an oven (chambers facing down) and see if the seat falls out.
Mueller
post Jul 1 2018, 10:50 AM
914 Freak!
QUOTE(thelogo @ Jun 30 2018, 08:58 PM) *
The valves move in the same direction of the pistons, they are not canted or at an angle relative to the piston top so if you get lucky they just get pushed back straight if they contact a piston.
r_towle
post Jul 1 2018, 10:52 AM
Custom Member
pistons put in upside down?
thomasotten
post Jul 1 2018, 11:21 AM
Photo of the stuck valve. When this happened to
the other head, I removed the spring,
and gave the valve a little tap and it came right
out. I then put it back in the guide and it was smooth.
There was some evidence of fine brass flakes, but on a
different valve spring.
Someone suggested possibly lifter catching. I checked them all,
and if you press down on the lifter when pulling you can feel
a small catch, but I think this is because the lifter is crossing a chasm in it’s travel in the case. I will probably replace them all. Cam off by one tooth? I usually triple check, but at this point anything is possible . I don’t know maybe I should just tear the whole case apart.
Looking over the sales receipt from Rimco, they reamed the guides on both heads originally. When I sent the other head back, they replaced the guides rather than reeming. So perhaps there is something with their reaming process ?
sixnotfour
post Jul 1 2018, 12:17 PM
top end oiling problem ?? no lube
Mark Henry
post Jul 1 2018, 02:33 PM
that's what I do!
I'd check the clearance of the guides, most shops use a Go-No Go gauge, but it as simple as feel for an experienced machinist, if it catches before the spring goes on it will seize when hot.
Another cause for this is bad gas, varnish, new engine always use brand new gas.
This could just be caused by your issue, but that is lean city, brown exhaust valve, bright white electrode.
Mark Henry
post Jul 1 2018, 02:36 PM
that's what I do!
Maybe you should get your injectors checked/cleaned and flow tested.
thelogo
post Jul 1 2018, 02:50 PM
QUOTE(thomasotten @ Jul 1 2018, 10:21 AM) *
Gotta give you major credit for turning your own wrenchs
But man this just affirms the fact rebuilding you're engine takes a certain amount of skill that i dont have. (IMG:style_emoticons/default/wub.gif)
thomasotten
post Jul 1 2018, 04:26 PM
QUOTE(Mark Henry @ Jul 1 2018, 12:36 PM) *
Will do. The engine didn't run for very long, so I am not sure if I have a lean condition. I understand that valve guide lubrication occurs from the rocker side oil. Someone on the phone at the machinist was telling me it is also lubed by gasoline spray. I can't see how that would work. In any case, does someone have the specs so I can measure for myself if the valve guides were reemed properly?
thomasotten
post Jul 1 2018, 05:01 PM
So, after sitting on the workbench for a few hours, I noticed that the
valve sprung back closed on its own. So I got the spring compressor
and removed thr spring. Gave the stem a little tap with a rubber hammer: Valve was tight! It came out with a few taps. I immediately noticed the fine
Brass shavings again. Here I point to one...
rgalla9146
post Jul 1 2018, 05:05 PM
Most likely issue is the guides are too tight.
- Lo-Fi Version Time is now: 2nd April 2026 - 11:38 AM
