Turn Signal and Wiper Switch Removal |
PDXMike |
Jul 2 2018, 06:39 PM
Slowly Learning Group: Members Posts: 111 Joined: 20-December 10 From: Portland, OR Member No.: 12,501 Region Association: Pacific Northwest |
How do you remove the Turn Signal Switch Stalk? I have the steering wheel off and I have removed the 4 screws. It looks like I need to remove the Wiper Switch Stalk, too so I can get at the connectors, but I can't figure out how to get it off of the there.
carking1996 |
Jul 2 2018, 06:56 PM
Member Group: Members Posts: 69 Joined: 15-September 16 From: Ohio Member No.: 20,399 Region Association: North East States |
Took me a minute to figure out, too. Easiest way I found was to take off the bottom dash cover part, then there are the connectors you can see in a hole in the column cover there. Unplug those and they'll slide right out.
914Sixer |
Jul 2 2018, 07:37 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Make sure you drain the windshield washer bottle otherwise you will have a wet driver floor. Be careful pulling on rubber hoses. Note where the striped line goes.
PDXMike |
Jul 2 2018, 08:05 PM
Done. Taking off the lower dash did the trick. With the connectors unplugged everything came out pretty easily. It's all buttoned back up with the new switch in place and working great. Thanks!!!
Lo-Fi Version | Time is now: 10th June 2024 - 07:45 AM |
