| worn |
Jul 11 2018, 06:11 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,660 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
I have been wondering a lot lately if there is an equivalent of a light weight sports car like a 914 made for today’s drivers. The 914 seems to have been focused on driving, rather than comfort: my 61 Falcon was no less comfortable or optioned. I know they have to pass safety and emissions. A toybaru?
| sb914 |
Jul 11 2018, 06:26 PM
Surf Guru ![]() ![]() ![]() ![]() Group: Members Posts: 4,700 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California
Where have you been? (IMG:style_emoticons/default/poke.gif)
| Andyrew |
Jul 11 2018, 06:45 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,381 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
Miata is probably as close as we get this side of the pond for a reasonable cost.
My fiesta ST gave me a very 914'y vibe with all the 70's colors available, punchy throttle and amazing balance. Toybaru is similar, geared towards more of a sports car than the Fiesta with a focus more on JDM nostalgia and driver feel than speed. The Alpha Romeo 4c spyder and Lotus Elise if were going to compare relative costs is probably as close as we can go with the Alpha close to what a modern interpretation would be due to its luxury, as the 914 wasnt a stripped down car like the lotus, it was a refined modern sports car of its time. |
| Mike Bellis |
Jul 11 2018, 06:48 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
| Mark Henry |
Jul 11 2018, 07:22 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Boxster and Cayman but they're heavier, the Lotus is about the only one that's ballpark the same weight.
| DRPHIL914 |
Jul 11 2018, 07:57 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,971 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
yes, this is close- of course it is heavier, isn't everything now compared to then? like a '72 911 vs a 2002 911- bigger , heavier but faster! so we have a mid engined car etc.
Attached thumbnail(s) |
| 914forme |
Jul 11 2018, 08:42 PM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
What about the Atom, designed only to be about driving, of course the new model the 4 has tipped the scales over the $104,000 mark (IMG:style_emoticons/default/confused24.gif)
And it will give you a nice facial to boot. |
| davesprinkle |
Jul 11 2018, 08:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None
MR2 Spyder
| Andyrew |
Jul 11 2018, 09:17 PM
| Chris914n6 |
Jul 11 2018, 11:17 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,565 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I think it's the Nissan 240sx.
Common upgrades: 5 lug swap for bigger brakes and better wheel selection. Underpowered. 145hp is not enough for 2800lbs. Great driving dynamics. Cheap, at least until drifting took off. Now you can't find an unmolested example. Rust problems, mostly from the rear wing and C-pillar drainage. Easiest motor upgrade is the home market 200hp 2.0L turbo. Other swaps.... Nissan I6, V6 and V8, Toyota I6 and V8, plus SBC and LSx. Body kits galore. Sounds like a 914 to me (IMG:style_emoticons/default/lol-2.gif) |
| mgp4591 |
Jul 12 2018, 12:09 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,063 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region
I think the mid engine is and important part of what makes the 914 what it is. The Boxster is of the type but so much heavier. The Lotus and the Alfa are the same type of layout except for the transverse engine and trans combo but that design centers the weight even more that the longitudinal format. There's no true comparison these days - that's why we try to bring a modern vibe to our little cars. There is a type of annoying magic to the original type of restorations but the ones that are modified with modern drivetrains may be the answer with improved driveability and good manners, real heat, and real a/c. Not disparaging the original design at all - very good for the time. But if we upgrade most systems and still retain that balance and charm, we've made the modern 914.
| Mueller |
Jul 12 2018, 12:44 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,157 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Alpine A110?
| IronHillRestorations |
Jul 12 2018, 04:37 AM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,958 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
Boxster
| Beebo Kanelle |
Jul 12 2018, 04:48 AM
Member ![]() ![]() Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region
| Racer |
Jul 12 2018, 05:46 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
Ideally a "modern" 914 is mid-engine with an open top... so Lotus Elise, Alfa 4C, MR2 spyder. As for Porsche, the bargain equivalent is a 986 Boxster.
Miata is a close second if only because it has been around so long and is such a versatile platform, despite not being mid-engined. Race car. Street car. AX/DE car. Grocery getter etc. Cheap to buy and maintain. Strong aftermarket support etc. |
| VaccaRabite |
Jul 12 2018, 07:07 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,930 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
I can say that driving a BRZ/FRS/AE86 whatever you call them now feels a LOT like driving a modern 914, even though its a front/rear setup instead of mid engine.
So much so that I have been considering picking one up. Zach |
| walterolin |
Jul 12 2018, 07:57 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
718 Cayman.
Least expensive modern Porsche. 2.0 four cylinder boxer engine (it is turboed). The purists turned their collective noses up at it when it came out - wasn't a real Porsche, didn't sound like a six (did they know it wasn't a six?). Mid engine, wheels at the corners, discs all around, no place to put your pocket book. Noisy inside because the engine in a way is inside the cabin and right behind you. Two trunks. MT available. Difficult for an old man to get in/out. Gets a lot of attention, and is faster than most of the preceding generation Boxster/Caymans. 300 hp, 20 lbs of boost. 0-60 in the 4.7 - 4.9 range. On the other hand, it is not a targa, doesn't rust, and weighs around 3000 lbs. Incredibly complex, takes over an hour just to get the engine cover off. For example, the fuel pump is thee phase AC. The MR2 and Spyder were great cars, my son had one. Unfortunately, like the S2000, they don't make them any more |
| Olympic 914 |
Jul 12 2018, 08:06 AM
![]() ![]() ![]() Group: Members Posts: 1,795 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States
718 Cayman. Least expensive modern Porsche. 2.0 four cylinder boxer engine (it is turboed). The purists turned their collective noses up at it when it came out - wasn't a real Porsche, didn't sound like a six (did they know it wasn't a six?). Mid engine, wheels at the corners, discs all around, no place to put your pocket book. Noisy inside because the engine in a way is inside the cabin and right behind you. Two trunks. MT available. Difficult for an old man to get in/out. Gets a lot of attention, and is faster than most of the preceding generation Boxster/Caymans. 300 hp, 20 lbs of boost. 0-60 in the 4.7 - 4.9 range. On the other hand, it is not a targa, doesn't rust, and weighs around 3000 lbs. Incredibly complex, takes over an hour just to get the engine cover off. For example, the fuel pump is thee phase AC. All of this..... That's why I bought one. Got the Cayman S 2.5 L Turbo 4, 350 HP And its Blue. Most of the magazines said it doesn't sound like a Porsche, I think it sounds great but I have never owned a Porsche six. Odd but a 924/944 928, Panamera, Macan, Cayanne etc. don't sound like a Porsche six either. |
| theer |
Jul 12 2018, 08:36 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 692 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States
Cayman is a great choice, but way too civilized.
The 924/944/968 was similarly stigmatized regarding the motor (underpowered - except for the Turbo). Not mid-engine, but has phenomenal handling & balance. They are pretty cheap to buy & own, for the time being, have a huge fan base out there, and have been modified for massive power (read: LS1). Galvanized body makes rust so much less of an issue. Lastly, these too suffer from battery box failure. Only here, the failure results in water draining onto the passenger's feet, rather than the rear wheel falling off - how's that for progress?!!. |
| krazykonrad |
Jul 12 2018, 10:41 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,182 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
Lo-Fi Version | Time is now: 4th November 2026 - 02:06 AM |
