FS: FACET Electric Fuel Pump 12V for Carburated Setup |
9144me2enjoy |
Aug 12 2018, 06:40 PM
Member Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
FS: I have a USED FACET Fuel Pump 12V Posi-Flo EFP-3 #60104 for Carburated engines, works fine. New they run $59.86 Amazon. I will take $30.00 plus Shipping.....Facet Posi-Flow Electric Fuel Pump No. 60104 for carburettor vehicles
This is an outstanding, lightweight universal Facet electronic fuel pump with state-of-the-art design that can be used in all carburettor-equipped vehicles and also as a diesel lift pump. In many applications, the advanced technology engineered into the Facet POSI-FLO fuel pump allows for a convenient interchange with the cube fuel pump. In addition it runs quieter, 65DB, versus the noise levels exhibited by earlier competitive solid state technologies. It is rated for 6000 hours of performance. The Facet Posi-Flo Fuel Pump's self-priming capabilities provide up to 12 inches of fuel lift and no extended cranking is necessary to restart the engine if "out-of-fuel" conditions occur. Specification: Posi-Flow Pump Pump Part Number. 60104 Voltage 12v Earth Negative Pressure (Psi) 1.5-4.0 Flow: US Gallons per Hour 25 Height 0.3 metres NOT suited for vehicles with fuel injection. Two-bolt installation plus the small size makes installation easy. For best results, mount the pump close to fuel tank and within 12 vertical inches of fluid level. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 12th June 2024 - 06:29 AM |
