| Driver174 |
Aug 22 2018, 11:14 AM
Member ![]() ![]() Group: Members Posts: 122 Joined: 2-February 17 From: Nevada Member No.: 20,806 Region Association: None
I’m looking for stepped up pins so I can increase diameter of mating hole in case but use unaltered bearing.
What is the fix for a worn dowel / case? I’m going to try a new dowel but I’m expecting it to be less than a tight fit. |
| Mark Henry |
Aug 22 2018, 11:22 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
On the type one case I machine drill it oversize for a press fit aluminum plug, then drill it to dowel size and finish it off by line bore the case for OS bearings.
Lo-Fi Version | Time is now: 16th April 2026 - 07:27 AM |
