> Replacing Boge Front Shocks Inserts, Do I need to align the front end after?
jagalyn
post Sep 19 2018, 12:45 PM
True Patina
I will be replacing the boge shock inserts on my car. Will I have to align the front end afterwards?
Replies(1 - 5)
post Sep 19 2018, 12:48 PM
914-6 GT in waiting
No
jcd914
post Sep 19 2018, 01:21 PM
If you leave the camber plate/strut mount bolted in place and just undo the single big nut and pull the shock insert down out of the camber plate/strut mount.
Jim
jagalyn
post Sep 19 2018, 07:23 PM
True Patina
Thank you... I appreciate the advise.
porschetub
post Sep 20 2018, 01:37 PM
No,however you will most likely need to adjust your ride height,I needed to as my car came out way to high after the change.
jcd914
post Sep 20 2018, 09:42 PM
If you use gas pressure inserts you may have to readjust the ride hieght.
Non gas pressure inserts should not impact the ride hieght.
None of the Boge inserts I have installed were gas pressured.
Koni had both gas and non gas, Bilstein are gas KYBs are gas and terribly harsh.
Jim
- Lo-Fi Version Time is now: 9th June 2026 - 08:00 AM
