rotational squeak |
rotational squeak |
JFG |
Sep 25 2018, 07:02 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
i have brand new tyres (avon zt5) on all corners. now that i can drive the car i have noticed a rotational squeak, like tyre rub but it's not the cause.
sounds like it's coming from the drivers side. i've spun and forced a pull/push on everything but cannot replicate or find any noise when not driving. any ideas |
mgphoto |
Sep 25 2018, 11:35 AM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Had the same squeak, passenger side, turned out to be a seized ball joint.
Actually torn the ball joint out of the A-arm, just after getting off the freeway doing 70+ MPH. Just very lucky! |
taylspin46 |
Sep 25 2018, 12:38 PM
Newbie Group: Members Posts: 24 Joined: 25-January 13 From: Apopka Member No.: 15,422 Region Association: South East States |
i have brand new tyres (avon zt5) on all corners. now that i can drive the car i have noticed a rotational squeak, like tyre rub but it's not the cause. sounds like it's coming from the drivers side. i've spun and forced a pull/push on everything but cannot replicate or find any noise when not driving. any ideas Try light pressure on brake pedal and see if squeak changes. Also move steering wheel side to side and see if that changes. 9 |
taylspin46 |
Sep 25 2018, 03:16 PM
Also check to see if backing plate got tweeked when tires installed.
TheCabinetmaker |
Sep 25 2018, 03:27 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Yep. It happens
JFG |
Sep 26 2018, 10:00 AM
it was the pad retaining plate rubbing against the outer edge of the disc, a little bit of filing and noise is gone
Lo-Fi Version | Time is now: 6th June 2024 - 06:46 PM |
