> How do you remove the window crank, then how do you put it back on
mistro
post Jun 17 2005, 08:38 PM
I need to remove two black mismatched window cranks and replace with some shiny chrome ones. How do I remove the existing cranks? TIA Rgds, Michael
Replies(1 - 5)
mihai914
post Jun 17 2005, 08:43 PM
Just pull on the plastic covering of the crank on the round part (not the turn knob), once unclipped, you should see a phillips screw, that's it.
ClayPerrine
If you peel back the plastic cover, you will see a phillips head screw. Just remove it and the crank will pull off.
If you are really anal, make sure the window is rolled up, and then when you reinstall the crank it should point forward and down at a 45 degree angle.
(I am picky about the angle of my crank (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) )
jet1
post Jun 17 2005, 08:46 PM
If I remember correctly, they should be held in place with a screw. Just pry off the plastic cover.
jet1
post Jun 17 2005, 08:47 PM
Ha! I am way too slow!
tod914
post Jun 17 2005, 09:49 PM
If that fails, try a shot of adrenelin and a crowbar.
- Lo-Fi Version Time is now: 8th December 2025 - 04:56 AM
