| PanelBilly |
Oct 29 2018, 12:29 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest
| GregAmy |
Oct 29 2018, 12:40 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,644 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
http://www.mainelycustombydesign.com/
I seem to recall when I got mine in 2014 it was the last run and he was only making them for 912s and 356s. But someone organized a group buy for 20... Edit: maybe someone can organize that again? I'd buy another one for the race car. http://www.914world.com/bbs2/index.php?showtopic=241854 |
| jim_hoyland |
Oct 29 2018, 12:52 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,035 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
I was hoping 914Rubber might make these again; the demand seems good.
A 1 1/2” gauge face would make it easier to read Mark ??? |
| jim_hoyland |
Oct 29 2018, 12:54 PM
Originsal face size:
Attached thumbnail(s) |
| jim_hoyland |
Oct 29 2018, 12:55 PM
Preferred size:
@Mikey914 Attached thumbnail(s) |
| PanelBilly |
Oct 29 2018, 01:09 PM
This is for my 3.0 so I need something that will go in the tank.
| GregAmy |
Oct 29 2018, 01:26 PM
This is for my 3.0 so I need something that will go in the tank. Then you'll have to customize something; the ones we're talking about replace the 914 4-banger's dipstick with a gauge on top. I seem to recall that Harleys have a lot of aftermarket options for oil tank caps that replace the basic cap with an oil temperature gauge and probe, maybe something like that will work. Or, remove the tank and have someone weld in a bung for an analog gauge. |
| Ferg |
Oct 29 2018, 01:43 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None
I don't think the temp of the oil in the tank would be very useful data.
Since you already have what appears to be a temp gauge installed I will assume it's working but you are looking to get an idea oh what temp in relation to position on gauge. A easier solution is to buy an IR thermometer and go for a drive, when the gauge shows half way, pull over use the laser pointer on the sump and record a temp. do that for the known needle sweep of your gauge and you now know what temp your car is running. Ferg |
| dr914@autoatlanta.com |
Oct 29 2018, 04:08 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
| mb911 |
Oct 29 2018, 04:48 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,723 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
For a -6 the tank could be modified for a temp sensor but a dipstick gauge won't make the turn a 6 dipstick does..
| SO.O.C914er |
Oct 29 2018, 06:05 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,834 Joined: 18-July 16 From: Mission Viejo Ca Member No.: 20,199 Region Association: Southern California |
I would absolutely buy one. I looked for this about a year ago.....Paul (IMG:style_emoticons/default/agree.gif)
| wndsrfr |
Oct 29 2018, 06:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,460 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region
Here's an angle to try....food temperature probe that you can dip down into the oil tank....might be able to straighten it out and snake it down the dipstick tube on a T4 also...
With Amazon Prime it's $18 and you get it in two days... https://www.amazon.com/ThermoPro-TP-16-Ther...mperature+probe |
| Valy |
Oct 29 2018, 07:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
@panelbilly
I have a dipstick one from the last run. As much as like the idea, the gauge lost it's calibration pretty quickly (way off) so now I have just a pretty dipstick that tells me that my cold engine is at 375F. I have no idea how to recalibrate it. I think I only need to rotate the dial but don't know how. If someone knows how, please share. |
| Rob-O |
Oct 29 2018, 08:50 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,310 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region
@panelbilly I have a dipstick one from the last run. As much as like the idea, the gauge lost it's calibration pretty quickly (way off) so now I have just a pretty dipstick that tells me that my cold engine is at 375F. I have no idea how to recalibrate it. I think I only need to rotate the dial but don't know how. If someone knows how, please share. Usually the back of the gauge has a formed hex nut as part of the housing. Put a wrench on it and then with your other hand turn the temp gauge bezel/glass. Not sure what to use as a calibration medium but boiling water at 212 deg. F comes to mind. Not sure what the gauge face reads so not sure boiling water would work. |
| Valy |
Oct 29 2018, 09:43 PM
@panelbilly I have a dipstick one from the last run. As much as like the idea, the gauge lost it's calibration pretty quickly (way off) so now I have just a pretty dipstick that tells me that my cold engine is at 375F. I have no idea how to recalibrate it. I think I only need to rotate the dial but don't know how. If someone knows how, please share. Usually the back of the gauge has a formed hex nut as part of the housing. Put a wrench on it and then with your other hand turn the temp gauge bezel/glass. Not sure what to use as a calibration medium but boiling water at 212 deg. F comes to mind. Not sure what the gauge face reads so not sure boiling water would work. Thanks. I think that did the trick. Not sure how it happened so the credibility of the measurements will always be questionable though. |
| Rob-O |
Oct 30 2018, 05:33 AM
Could happen a few ways. But probably most common would be a twisting motion of the dipstick face while pulling the dipstick.
These are neat features to have but I agree that they’re highly susceptible to being waaayyyy wrong. |
| rmdinmd |
Oct 30 2018, 06:17 AM
Member ![]() ![]() Group: Members Posts: 489 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States
@panelbilly I have a dipstick one from the last run. As much as like the idea, the gauge lost it's calibration pretty quickly (way off) so now I have just a pretty dipstick that tells me that my cold engine is at 375F. I have no idea how to recalibrate it. I think I only need to rotate the dial but don't know how. If someone knows how, please share. Usually the back of the gauge has a formed hex nut as part of the housing. Put a wrench on it and then with your other hand turn the temp gauge bezel/glass. Not sure what to use as a calibration medium but boiling water at 212 deg. F comes to mind. Not sure what the gauge face reads so not sure boiling water would work. Before digital we used to use ice water (with ice in it) for 32F or steam (boil water and have thermometer set up in the steam not water) for 212F at sea level to calibrate our thermometers. Yes a twisting motion could change the setting so get used to pulling straight up. |
| dcheek |
Oct 30 2018, 07:21 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 692 Joined: 30-May 06 From: Westfield, New Jersey Member No.: 6,103 |
Mainely was bought by Precision Matters.
They still show the item for sale on their website: https://precisionmatters.biz/type-4-dipstick-thermometer.php Dave |
| VaccaRabite |
Oct 30 2018, 09:31 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,841 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
If you can get one of the Mainely units get one. I have found it very useful.
Zach |
| GregAmy |
Oct 30 2018, 11:34 AM
Ditto. It originally allowed me to verify my oil temps in the center console gauge, then "calibrate" points on the combo gauge when I removed the console.
Lo-Fi Version | Time is now: 14th March 2026 - 09:07 AM |
