| xperu |
Nov 1 2018, 11:21 AM
TEXAS ![]() ![]() ![]() Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None
When installing the 3 aluminum trim pieces on roll bar, are the 2 side trim pieces the only support for the top roll bare piece. The reason I’m asking is on my previous 914 I thought there was a clip in the center of the trim piece that fit in a hole in the bar to hold it in place. Thanks
| toolguy |
Nov 1 2018, 11:28 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,277 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California
the horizontal center bar should have 3 clips that secure it to the rollbar frame at the pinch weld seam
| mepstein |
Nov 1 2018, 11:51 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,914 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Those 3 trim clips hold it very secure. It takes a pretty good tug to remove.
| xperu |
Nov 1 2018, 12:34 PM
That’s what I thought. My car has no holes. Maybe covers during body work. I”ll start a search and find. Thanks guys. Mike
| mepstein |
Nov 1 2018, 01:07 PM
| xperu |
Nov 1 2018, 01:19 PM
That’s what I thought. My car has no holes. Maybe covers during body work. I”ll start a search and find. Thanks guys. Mike No holes. They clip on to the seam. OK Mark, I've had these off for about 10 years and could not remember, I will have to do a search and find some. Thanks Mike |
| mepstein |
Nov 1 2018, 01:27 PM
part # 914.559.223.10
About $10 each at the porsche dealer but you can probably find used. Maybe bdstone, Garold, ect @xperu Attached image(s)
| Chi-town |
Nov 1 2018, 01:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Anyone sell those three clips? Mine are missing also
| xperu |
Nov 1 2018, 01:29 PM
| xperu |
Nov 8 2018, 02:26 PM
part # 914.559.223.10 About $10 each at the porsche dealer but you can probably find used. Maybe bdstone, Garold, ect @xperu OK so now that I picked up the 3 clips, What is the best method to install. I looked at several threads, but no info. Like I said before it's been 10 years or so sense I removed the trim and really can't remember. I just do not want to screw things up. Thanks Mike |
| mepstein |
Nov 8 2018, 02:49 PM
part # 914.559.223.10 About $10 each at the porsche dealer but you can probably find used. Maybe bdstone, Garold, ect @xperu OK so now that I picked up the 3 clips, What is the best method to install. I looked at several threads, but no info. Like I said before it's been 10 years or so sense I removed the trim and really can't remember. I just do not want to screw things up. Thanks Mike Clip goes on the trim then push trim onto targa bar. Push straight on, it doesn’t slide on from the side. |
| dr914@autoatlanta.com |
Nov 8 2018, 02:51 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,243 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
| xperu |
Nov 8 2018, 03:37 PM
part # 914.559.223.10 About $10 each at the porsche dealer but you can probably find used. Maybe bdstone, Garold, ect @xperu OK so now that I picked up the 3 clips, What is the best method to install. I looked at several threads, but no info. Like I said before it's been 10 years or so sense I removed the trim and really can't remember. I just do not want to screw things up. Thanks Mike Clip goes on the trim then push trim onto targa bar. Push straight on, it doesn’t slide on from the side. Thanks Mark, ur always a big help. Thanks again. Mike |
| rgalla9146 |
Nov 9 2018, 01:03 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,997 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Just to clarify...The clips are slid into the horizontal aluminum trim then the piece is
pushed onto the pinch weld. |
Nov 9 2018, 01:15 PM
Lo-Fi Version | Time is now: 18th September 2026 - 04:30 PM |
