> Stearing bearing lube, What to use
trojanhorsepower
post Nov 19 2018, 08:58 PM
So, i am about ready to reattach the stearing column, but i need to lube the shaft stablizing bearing, so what are your recommendations ? Grease, oil, weight?
Thanks All,
Peter
Replies(1 - 5)
Mark Henry
post Nov 19 2018, 09:54 PM
that's what I do!
I use swepco 101 grease on just about everything.
On a bushing where I want a bit stickier/thinner I mix some 101 grease with a dab of blue STP or Lucas engine assembly lube.
I've used oil mixed with some blue STP in my oil can for years, great for anywhere you want oil that's a bit sticky. For T1/T4 engine assembly, lathe slides and anything you shoot with the oil can.
Krieger
post Nov 20 2018, 12:16 AM
(IMG:style_emoticons/default/agree.gif) I do exactly the same. Great minds think alike!
trojanhorsepower
post Nov 20 2018, 04:31 PM
Thanks Guys!
Ill see if I can find the Swepco 101.
Thanks again,
Peter
Mark Henry
post Nov 20 2018, 05:20 PM
that's what I do!
QUOTE(trojanhorsepower @ Nov 20 2018, 05:31 PM) *
Thanks Guys!
Thanks again,
Peter
Just call Swepco, they'll put you on to the local rep. I know pelican carries it.
trojanhorsepower
post Nov 20 2018, 09:28 PM
Thanks
- Lo-Fi Version Time is now: 12th July 2025 - 10:40 AM
