914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
As the title says:
$800 including shipping to lower 48 for all. The MPS is calibrated for a 2.0 and has been tested as are the ECU's. Distrubutor for the 2.0 has a bad vaccum pot but the other dizzy is fully functionally and runs well with good vaccum pots. Rob ![]() |
914_teener |
914_teener |
More
Attached thumbnail(s) ![]() |
914_teener |
914_teener |
914_teener |
914_teener |
JOEPROPER |
The answer is "no" unless you ask... ![]() ![]() ![]() Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States ![]() ![]() |
Wow what a great deal!
914_teener |
914_teener |
I.ll deliver free in the local So Cal area for members.
Last of my 2.0 stuff. Only reason I.m selling it is that I have a darkside six project now. |
914_teener |
This comes with the two 2.0 ECU's which have been tested as good.
2.0 Air Filter newly powder coated and a new air filter. 2.0 Throttle Body with TPS good. I.ll post more pics later. 2.0 "Green Top" fuel injectors. These came out of another car and were good then. I have tested the pintles and they do click. The should be cleaned and spray tested. Normally this goes for about $100. Working AAR Completely rebuilt MPS and tested. The kit was from Chris Foley and was calibrated by Jeff Bowlsby. Have the reciepts. This alone is more than $250. Two dizzy's. One is a 1.7 and the other from a 74 2.0. Powder coated silver 2.0 intake runners. 2.0 intake plenum pressure tested to 12 psi. No leaks. This has not been powder coated. Oil filler tower. Flamethrower coil. You will need a fuel pressure regulator and a harness to complete a conversion. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
914_teener |
Pm's responded to.
Jazzy |
Newbie ![]() Group: Members Posts: 32 Joined: 16-September 17 From: The Netherlands Member No.: 21,432 Region Association: Europe ![]() |
914_teener |
Jazzy |
Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
Thanks Rob, I will put these to good use.
Lo-Fi Version | Time is now: 11th June 2024 - 12:36 AM |
