> changing clutch
porsche-tom
post Nov 30 2018, 06:58 AM
I am going to be changing my clutch on my 72 1.7 soon. I have read up on it and it looks to be straight forward. I was wondering if it would be worth it to just drop the whole engine? any tips from past experience would be appreciated also!
Replies(1 - 10)
wndsrfr
post Nov 30 2018, 07:07 AM
If you're agile enough to drop the engine, then you can do the clutch without taking the engine out. Takes an hour or two under the car...best to have a helper. If you're by yourself, easier if you drop the engine.....make sense?
Spoke
post Nov 30 2018, 07:16 AM
Jerry
Unless you have other reasons like freshening up the tin or pushrod tubes or other engine work, I'd leave the engine in. I changed the clutch on my 914 leaving the engine in. This way I didn't have to disconnect any fuel/electric lines.
Tdskip
post Nov 30 2018, 08:49 AM
Excellent time to refresh your transmission mounts since you'll be touching them anyway.
(holy cow - did I just potentially pass on useful, albeit obvious, advice?)
dr914@autoatlanta.com
post Nov 30 2018, 09:06 AM
no way, when younger I used to change a 914 clutch in 45 minutes. Do NOT remove the engine!!!!!
QUOTE(porsche-tom @ Nov 30 2018, 05:58 AM) *
Mblizzard
post Nov 30 2018, 09:47 AM
QUOTE(dr914@autoatlanta.com @ Nov 30 2018, 07:06 AM) *
I too remember the days when I could bench press a 901 into position under the car because I only had one jack.
scott_in_nh
post Nov 30 2018, 10:15 AM
I'm at this point too, actually changing to what should be a better shifting transmission and figure I might as well do the clutch while I'm at it.
How high does the car need to go?
Better to leave the front tires on the ground or up on 4 jack stands?
Mblizzard
post Nov 30 2018, 10:45 AM
QUOTE(scott_in_nh @ Nov 30 2018, 08:15 AM) *
For just the trans, I typically just jack up the rear and leave the front wheels on ground.
You just need to get it high enough to pull the trans out from under it. Going higher just means you have to have a taller jack to lower the trans.
I like to loosen the bolts on the cross bar to lower the front of the engine a bit. Then remove the bolts on the trans and lower so that it clears the trans bolts. then support the engine at that angel. Makes removal and installing a bit easier.
ndfrigi
post Nov 30 2018, 10:57 AM
914Toy
post Nov 30 2018, 11:11 AM
While you are at it, replace the nylon pivot bushing for the clutch release fork.
pilothyer
post Dec 1 2018, 06:11 AM
QUOTE(dr914@autoatlanta.com @ Nov 30 2018, 09:06 AM) *
Totally agree, if that's all you need to do.
- Lo-Fi Version Time is now: 11th July 2025 - 12:53 PM
