OT: I'm stuck, don't know how to remove, A TRANNY W/ PULL TYPE CLUTCH |
root |
Jun 19 2005, 02:25 PM
Two Wheeled Type4 Completed! Group: Members Posts: 849 Joined: 5-May 04 From: Sterling, VA Member No.: 2,026 Region Association: None |
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) OK, I need some help here. I have everything loose, everything!
But the engine won't come out! Then I wipe grease off a label on the bottom of the tranny and it says:" PULL-TYPE CLUTCH REFER TO WORKSHOP MANUAL TO REMOVE TRANNY"? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Can someone give me a hint what to do! It's the RX7 below- Attached image(s) |
Series9 |
Jun 19 2005, 02:37 PM
Lesbians taste like chicken. Group: Members Posts: 5,444 Joined: 22-August 04 From: DeLand, FL Member No.: 2,602 Region Association: South East States |
915 trannys are the same. I remove the circlip from the clutch lever and the lever itself so the arm can rotate freely. The tranny will then come off.
Of course, these are instructions for a 915... |
root |
Jun 19 2005, 04:34 PM
914RS - Thanks I got on the rx7 forum (firsttimeever) and found the answer.
Just need to pry back the little ring retainer clip gizmo. The engine popped out. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 10:50 PM |
