rickso71 |
Member ![]() ![]() Group: Members Posts: 74 Joined: 31-October 04 From: Derry, NH Member No.: 3,041 ![]() |
I'm installing a PO's rebuild and can't figure out if there are warm air shrouds on the bottom of the engine, particularly covering the thermostat. Seems that the thermostat shouldn't be just sitting there in free air but I can't find any good photos of what the shrouding on the bottom side of the cylinders and around the thermostat should look like, or if there is even any there.
mihai914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None ![]() ![]() |
The thermostat is sitting in free air. I don't know af any good pictures for the cooling tin. You'll have to play the puzzle game for know but should be able to figure it out with patience. Maybe someone will chime in with some pictures shortly.
hmeeder |
Dante's Sportscar ![]() ![]() Group: Members Posts: 352 Joined: 21-November 04 From: San Diego, CA Member No.: 3,154 ![]() |
(IMG:http://partpricer.com/parts/115-05.gif)
I think you are referring to part 11 in Paul Heery's diagram. I believe they are also called "warm air guides" Part 11 is the driver's side and part 12 is the passenger's. It's not clear from this diagram put the driver's side changed in '73 due to the side shifter linkage. They';re not interchangeable. I found this out when I did a sideshifter conversion. |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
fyi #s 11 and 12 changed for the 75' type heat exhangers too.
k |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,098 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
rickso71 |
Thanks for the info and especially the photos. The thermostat bracket has another small bracket with a threaded hole in it which clued me that there was a guide that mounts using that threaded hole.
dmenche914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 ![]() |
the sheet metal under teh thermostat bellows also helps prevent road debries from puncturing the bellows. Good to have in place.
Lo-Fi Version | Time is now: 16th July 2025 - 03:57 PM |
