FS: pedal clusters, all or none |
zephyrblau |
Dec 13 2018, 01:58 PM
Newbie Group: Members Posts: 2 Joined: 30-June 14 From: castro valley, ca. Member No.: 17,567 Region Association: None |
as pictured. $100 + shipping. NO LONGER AVAILABLE
[attachmentid=678 761] [attachmentid=678 784] [attachmentid=678 788] Attached image(s) |
DLewis |
Dec 13 2018, 04:44 PM
Member Group: Members Posts: 63 Joined: 3-December 04 From: Poway, CA (was SF Bay area) Member No.: 3,212 Region Association: None |
can't see a picture but I am interested in buying.
Can you send me a picture? Dean |
zephyrblau |
Dec 13 2018, 04:50 PM
LMK if this works. the site software has been acting flakey today.
DLewis |
Dec 13 2018, 05:43 PM
pm sent
Dean |
zephyrblau |
Dec 15 2018, 05:06 PM
$75 + shipping.
bdstone914 |
Dec 15 2018, 08:44 PM
bdstone914 Group: Members Posts: 4,531 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Can you post any better pictures? How many are there? 3 or 4 ? One looks to have a bent brake pedal. Do they have the brake rods and brake light switches. Do the pedals move freely?
zephyrblau |
Dec 15 2018, 10:04 PM
zephyrblau |
Dec 16 2018, 03:39 PM
there are 2 units. the straight clutch arm may be 911 type (?)
Attached image(s) |
DLewis |
Dec 16 2018, 09:13 PM
I take it my PM offer wasn't acceptable?
I did hear back from you. Thanks, Dean |
zephyrblau |
Dec 17 2018, 12:49 PM
bdstone914 |
Dec 20 2018, 06:26 AM
Here is what you have. One 914 pedal set and one 911 pedal set. See the straight clutch pedal ? That is a 911. Also note the difference in the slot lenght of the elongated holes for the floor pan studs.
It is also missing one of the bolts that attach the master. The other 914 set is missing the brake rod and brake light switch. It may be the angle of the image but the brake pedal appears to be bent in the top image. The 914 set has been modified. Back on the 911 set. The brake light switch bracket was removed from the correct welded position and bolted on to the back edge of the housing. Why ?Look at the lower picture. |
Lo-Fi Version | Time is now: 1st June 2024 - 09:11 AM |
