How test the temp warning light? |
Tdskip |
Dec 18 2018, 03:14 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Hello gentlemen, hope everyone is having a good week so far.
My '73 only has a temp warning light and I'd like to know that it is good before I push the car into regular use. I'm clearly struggling trusting the car absent gauges that give me the information I'm used to.... Pull and ground one of the leads? Thanks! |
dr914@autoatlanta.com |
Dec 18 2018, 03:17 PM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
probably green oil pressure warning light, comes on when you turn the key to on, goes off when you start the car
Hello gentlemen, hope everyone is having a good week so far. My '73 only has a temp warning light and I'd like to know that it is good before I push the car into regular use. I'm clearly struggling trusting the car absent gauges that give me the information I'm used to.... Pull and ground one of the leads? Thanks! |
Tdskip |
Dec 18 2018, 03:19 PM
Hi George!
So, effectively, is the light coming on when ignition is turned on and then off when running all the test I need? Thanks. |
SirAndy |
Dec 18 2018, 05:51 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
So, effectively, is the light coming on when ignition is turned on and then off when running all the test I need? Yes, as long as you stop referring to it as a "temp warning light" ... oil temperature != oil pressure (IMG:style_emoticons/default/shades.gif) |
Tdskip |
Dec 18 2018, 05:53 PM
So, effectively, is the light coming on when ignition is turned on and then off when running all the test I need? Yes, as long as you stop referring to it as a "temp warning light" ... oil temperature != oil pressure (IMG:style_emoticons/default/shades.gif) Can I call it a flux capacitor? (IMG:style_emoticons/default/evilgrin.gif) |
worn |
Dec 18 2018, 07:15 PM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
So, effectively, is the light coming on when ignition is turned on and then off when running all the test I need? Yes, as long as you stop referring to it as a "temp warning light" ... oil temperature != oil pressure (IMG:style_emoticons/default/shades.gif) Can I call it a flux capacitor? (IMG:style_emoticons/default/evilgrin.gif) No |
Tdskip |
Dec 18 2018, 07:56 PM
So, effectively, is the light coming on when ignition is turned on and then off when running all the test I need? Yes, as long as you stop referring to it as a "temp warning light" ... oil temperature != oil pressure (IMG:style_emoticons/default/shades.gif) Can I call it a flux capacitor? (IMG:style_emoticons/default/evilgrin.gif) No LOL, Oil temperature warning light it is then |
SirAndy |
Dec 18 2018, 08:53 PM
LOL, Oil temperature warning light it is then It's your engine, just remember, it has 3 settings: - Light comes on, engine is at operating temp - Light starts flashing, engine is getting hot - Horrible noise from the back, you looked at the wrong indicator (IMG:style_emoticons/default/rolleyes.gif) |
Tdskip |
Dec 18 2018, 10:04 PM
OK then!
Think I am going to install a proper gauge soon. Thanks gentlemen |
VaccaRabite |
Dec 19 2018, 01:47 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Just to be clear...
The green light has nothing whatsoever to do with oil temperature. It is oil pressure. And if it turns on while the car is running, turn the car off ASAP or the car will turn itself off permanently. Zach |
SirAndy |
Dec 19 2018, 04:36 PM
Just to be clear... The green light has nothing whatsoever to do with oil temperature. It is oil pressure. And if it turns on while the car is running, turn the car off ASAP or the car will turn itself off permanently. (IMG:style_emoticons/default/agree.gif) Somebody needs to invent a sarcasm font because my previous post was meant to be somewhat snarky yet funny. (IMG:style_emoticons/default/shades.gif) |
rhodyguy |
Dec 19 2018, 04:43 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,092 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
No font required. I got it straight away. Owner's manuals come in handy. Sarcasm.
Tdskip |
Dec 19 2018, 05:30 PM
Just to be clear... The green light has nothing whatsoever to do with oil temperature. It is oil pressure. And if it turns on while the car is running, turn the car off ASAP or the car will turn itself off permanently. Zach Thank you Zach, that is actually very helpful. I missed the sarcasm angle, running around doing 100 things at once and, well, I just missed it. This kind of brings me back to the original question, which is with a stock car that doesn’t have the appearance package there really isn’t a way to have early warning that the car is thermal profile is unhealthy. |
SirAndy |
Dec 19 2018, 05:45 PM
Thank you Zach, that is actually very helpful. How did you actually *not* read the "it's oil pressure" replies above until Zach posted? I mean, every single response in this thread was people telling you that it's oil pressure, yet you kept coming back to oil temperature right up until Zach's post. I don't get it ... (IMG:style_emoticons/default/confused24.gif) |
Tdskip |
Dec 19 2018, 05:51 PM
How did you actually *not* read the "it's oil pressure" replies above until Zach posted? Best answer is I am a moron at times, and I'm mentally hung up on my reference point with the other cars of the same vintage. I don't think I'm lacking separate oil pressure and engine temperature gauges on any of my other vintage stuff. To be extra clear - my response to Zach was NOT intended to give you or anyone else a hard time. I am very appreciative of the help from you and George and everyone else. |
Dave_Darling |
Dec 19 2018, 06:10 PM
This kind of brings me back to the original question, which is with a stock car that doesn’t have the appearance package there really isn’t a way to have early warning that the car is thermal profile is unhealthy. Very possibly because they were built to a price. Also, the Bugs never had them, nor the Buses. To some people, the temp gauge is just one more thing to worry about. Though I'm a fan of knowing what is going on in the engine, so I like having a gauge... --DD |
Lo-Fi Version | Time is now: 9th June 2024 - 09:59 AM |
