Trevorg7 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,242 Joined: 7-December 04 From: Highland Village, TX Member No.: 3,241 Region Association: Southwest Region ![]() |
So I need some advice (for the newbie). I finally got around to posting pictures of my car, that I've had since December 04, on the nailed link above. Attached is a rear view and what I believe is a monza exhaust. Is there a valance that is available and will accomodate the dual exhaust pipes?
Thanks T Attached image(s) ![]() |
fadler1 |
Newbie ![]() Group: Members Posts: 24 Joined: 30-June 04 From: San Diego, CA Member No.: 2,278 ![]() |
I have never found one. I saw some guy cut down and it looked lousy.
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
valances and hole saws are available from many sources.
no 914 road car ever came with dual exhaust... |
thomasotten |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,565 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 ![]() |
No there isn't one with two notches. Factory valances all have single notches. So you could use one of those, and just fiberglass the notch away. Or, you could do what I am going to do: get rid of my obnoxiously loud monza and go OEM or triad.
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,258 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) is all you need ...
obviously, you don't have to go quite as nuts about the cutting as i did ... (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) Andy Attached image(s) ![]() |
Trevorg7 |
Thanks everyone. Seems like a new exhaust system is in order or no valance but that looks odd to me.
T |
Ray Warren |
Member ![]() ![]() Group: Benefactors Posts: 415 Joined: 1-October 03 From: Canada Member No.: 1,214 Region Association: None ![]() ![]() |
You could do something like this.
I cut the dual tips off and put on a pair of stainless tips and installed a (no notch) valance. Attached image(s) ![]() |
Ray Warren |
nuter angle
Ray Warren |
oops
type47fan |
It Looks Better In Person. . . ![]() ![]() ![]() Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California ![]() ![]() |
Here's a picture of one I modified for an ANSA I had on the '72 1.7 circa '79. The car is long gone but I kept the valance.
I bent steel brake line to fit the contours of the openings I cut and brazed them onto the valance. Measuring for the openings took longer than the fitting and welding. Still only spent 2-3 hours on the whole project. Good luck with yours! Attached image(s) ![]() |
Lo-Fi Version | Time is now: 19th July 2025 - 04:45 AM |
