Wiring question |
Wiring question |
mlindner |
Feb 7 2019, 09:36 AM
Senior Member Group: Members Posts: 1,528 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
I'm relocating my battery to the rear trunk via a kill switch. How can I find out what the four red wires going to the + battery terminal are for. Best, Mark
76-914 |
Feb 7 2019, 09:44 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
One goes to the steering column, one to the fuse panel in the cabin, one to the relay board. Not sure about the 4th (IMG:style_emoticons/default/beerchug.gif)
JeffBowlsby |
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Look on the schematic maybe?
mlindner |
Feb 7 2019, 03:22 PM
Thanks 76-914....yes to ignition, one to fuse panel under dash, and two to the relay board (pins 12 & 14). And I'll get back to you Jeff. Need engine wiring harness for a carbed 2.2 six. Best, Mark
Lo-Fi Version | Time is now: 8th June 2024 - 12:01 AM |
