spaceshuttle |
Member ![]() ![]() Group: Members Posts: 73 Joined: 25-November 06 From: SouthCarolina Member No.: 7,258 ![]() |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,438 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Very South Carolina,,, wide five hubs (IMG:style_emoticons/default/wub.gif)
https://www.ebay.com/itm/Porsche-914-Sherid...f:0&vxp=mtr |
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
It looks fast just sitting still.
Brett W |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None ![]() ![]() |
Some of it is interesting, but look closely and there is a lot of WTF going on there.
The gauges look really hard to read Lot of unnecessary original 914 sheetmetal left. The aluminum front undertray won't survive one off road incident That front perimeter tubing is about scary as hell. It might not break off in an impact. Stock lower control arms and rubber or poly bushings? Way to cheap out Stock four banger front sway bar The Cell on the passenger side is a nice move. I like the wide five parts. Too Much money for too little "good car". |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Adapters on the rear....was so hoping real wide 5 in the back.
spaceshuttle |
Where do you think the car should be priced Brett W?
Some of it is interesting, but look closely and there is a lot of WTF going on there. The gauges look really hard to read Lot of unnecessary original 914 sheetmetal left. The aluminum front undertray won't survive one off road incident That front perimeter tubing is about scary as hell. It might not break off in an impact. Stock lower control arms and rubber or poly bushings? Way to cheap out Stock four banger front sway bar The Cell on the passenger side is a nice move. I like the wide five parts. Too Much money for too little "good car". |
ablesnead |
Member ![]() ![]() Group: Members Posts: 157 Joined: 16-September 13 From: United States Member No.: 16,395 Region Association: None ![]() |
A tub car that should of been a tube car..I mean if is that close ......
Brett W |
Where do you think the car should be priced Brett W? Some of it is interesting, but look closely and there is a lot of WTF going on there. The gauges look really hard to read Lot of unnecessary original 914 sheetmetal left. The aluminum front undertray won't survive one off road incident That front perimeter tubing is about scary as hell. It might not break off in an impact. Stock lower control arms and rubber or poly bushings? Way to cheap out Stock four banger front sway bar The Cell on the passenger side is a nice move. I like the wide five parts. Too Much money for too little "good car". Maybe $8K or less. The body work is fairly expensive, but overall, when you dig into the whole package there isn't a whole lot of REALLY nice parts. The rear shocks are garbage QA1, the front struts are unknowns, the Hoosiers are of unknown dates, The front suspension is stock 914 parts with rubber bushings, small sway bar, etc. The rear is probably similar suspension. I suspect the fuel cell needs replacing as its long out of date if it came from the 90s. Its a novelty, that really fits no where in club racing without a Porsche motor and the class it ends up in, the car would be hopelessly out matched. The suspension geometry wasn't corrected when there was the opportunity, the ergonomics of the driver's compartment looks all wrong, the roll cage design is questionable at best. Lots of unsupported nodes and generally poor design. As I am guessing this is your car for sale, this will sound like I am pissing all over your pride and joy, but just stating observations based on the pictures. |
spaceshuttle |
Fuel cell and Hoosiers are 2 years old.
Hardly my pride and joy. Just something I bought and repaired. And the paint and Body was 8K Thanks for your honest, albeit harsh opinion.LOL Where do you think the car should be priced Brett W? Some of it is interesting, but look closely and there is a lot of WTF going on there. The gauges look really hard to read Lot of unnecessary original 914 sheetmetal left. The aluminum front undertray won't survive one off road incident That front perimeter tubing is about scary as hell. It might not break off in an impact. Stock lower control arms and rubber or poly bushings? Way to cheap out Stock four banger front sway bar The Cell on the passenger side is a nice move. I like the wide five parts. Too Much money for too little "good car". Maybe $8K or less. The body work is fairly expensive, but overall, when you dig into the whole package there isn't a whole lot of REALLY nice parts. The rear shocks are garbage QA1, the front struts are unknowns, the Hoosiers are of unknown dates, The front suspension is stock 914 parts with rubber bushings, small sway bar, etc. The rear is probably similar suspension. I suspect the fuel cell needs replacing as its long out of date if it came from the 90s. Its a novelty, that really fits no where in club racing without a Porsche motor and the class it ends up in, the car would be hopelessly out matched. The suspension geometry wasn't corrected when there was the opportunity, the ergonomics of the driver's compartment looks all wrong, the roll cage design is questionable at best. Lots of unsupported nodes and generally poor design. As I am guessing this is your car for sale, this will sound like I am pissing all over your pride and joy, but just stating observations based on the pictures. |
Brett W |
That's great, the fuel cell will help sell it as that is not an extra expense for the buyer. The paint and body work look really nice, so that helps. By now the Hoosiers are good for a quick ride around the track as a check out. They will have no grip left in them, but no sense in adding fresh rubber now, let the new ower deal with it.
Could be a hell of an interesting WRL/AER car but you would only be able to do day races. (Unless the new owner cut up and put some lights on it) Stick a 604 crate motor in and it will pretty much last forever. Not sure how well the trans will hold up. |
jd74914 |
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States ![]() |
Pretty car. I really like the color scheme and full molded rear.
The cage is odd. Don't really care for the design, lack of nodes, or molded in roll hoop. Does it have rust pitting on the drivers "a-pillar" bar or is that just a paint thing? |
spaceshuttle |
I find no rust on the car. The back sides of the pillars did not receive the same amount of attention as the front sides if maybe that’s what you are referencing? I kind of like
the molded in hoop, although I’m sure it was a pile of extra work. Pretty car. I really like the color scheme and full molded rear. The cage is odd. Don't really care for the design, lack of nodes, or molded in roll hoop. Does it have rust pitting on the drivers "a-pillar" bar or is that just a paint thing? |
spaceshuttle |
Yeah I have a fresh 358 SBC that I can put in. It even has some really cool upswept custom headers. Didn’t offer it that way because thought maybe someone may want to go air cooled. I will install it and the Boxster S tranny if it doesn’t sell as a roller.
That's great, the fuel cell will help sell it as that is not an extra expense for the buyer. The paint and body work look really nice, so that helps. By now the Hoosiers are good for a quick ride around the track as a check out. They will have no grip left in them, but no sense in adding fresh rubber now, let the new ower deal with it. Could be a hell of an interesting WRL/AER car but you would only be able to do day races. (Unless the new owner cut up and put some lights on it) Stick a 604 crate motor in and it will pretty much last forever. Not sure how well the trans will hold up. |
Brett W |
After looking at a couple of the cage pics more closely, I have some concerns about the legality of the roll cage. Looking at one of the pics from the passenger side looking at the driver's a-pillar. IS that one continuous tube from the main hoop to the floor? It looks like it stops in the middle of the door bar
spaceshuttle |
After looking at a couple of the cage pics more closely, I have some concerns about the legality of the roll cage. Looking at one of the pics from the passenger side looking at the driver's a-pillar. IS that one continuous tube from the main hoop to the floor? It looks like it stops in the middle of the door bar No it goes all the way to the floor. It does change colors, but it is continuous. ![]() |
Brett W |
Thats not the one I am talking about. The one I am referring to is the front driver's side A-pillar bar. Where it goes down near the front of the door/dash junction:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.ebayimg.com-1169-1550550787.1.jpg) |
Lo-Fi Version | Time is now: 17th June 2024 - 06:10 AM |
