Wiper washer connections at switch...4 connections? |
doug_b_928 |
Feb 18 2019, 10:45 AM
Did some washer switches have 4 connections for water lines? Mine has the usual two lines that go through the firewall, but there is a third line that appears to 'jumper' two additional ports (see below). Is this normal? (IMG:style_emoticons/default/confused24.gif)
Chi-town |
Feb 18 2019, 11:01 AM
For the euro headlamp washers?
doug_b_928 |
Feb 18 2019, 11:36 AM
Hmmm...that would be consistent with this mystery pump that Jeff Bowlsby posited might be for the headlight washers.
The front bumper top doesn't have holes for nozzles and my car is a NA model. Maybe someone on the line thought that this car was getting that option... |
914Sixer |
Feb 18 2019, 12:26 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Not for headlight washers. It used a Audi/VW pump. Make sure your hose is not double back into column. There is only room for two hose connections.
dr914@autoatlanta.com |
Feb 18 2019, 12:33 PM
914 Guru Group: Members Posts: 7,894 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Lo-Fi Version | Time is now: 7th June 2024 - 12:32 PM |
