914 Airbox HELP, air box control lever fastening bolt |
Str1974 |
Feb 26 2019, 10:30 AM
Member Group: Members Posts: 90 Joined: 23-January 19 From: Dallas Member No.: 22,820 Region Association: Southwest Region |
Help, I just refurbished my air box (1974 1.8) with new seals etc. After getting the air box assembled and back into it's place under fresh air vent (what a pain to get those two bolts to line up...)
I can't find the bolt that I had disconnected from the cable (see image #3) As usual I put it in a special place so I would not lose it....yea right. I have gone thru the parts diagram available and I cannot find the bolt that has the small hole in it that allows the cable to go thru it and fasten with washer /nut. I have found the part# for the fastening clamp, but not for the bolt at the end of cable. All the bolts I see available do not have the "eye" hole in it for the cable to go thru and tighten. It won't take a barrel nut in its place. |
76-914 |
Feb 26 2019, 10:35 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If no one comes on board with a replacement part try here: https://www.aircraftspruce.com/menus/ha/bolts.html
Str1974 |
Feb 26 2019, 10:46 AM
If no one comes on board with a replacement part try here: https://www.aircraftspruce.com/menus/ha/bolts.html will do, thx |
iankarr |
Feb 26 2019, 10:56 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,481 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
These are on ebay....
https://www.ebay.com/itm/LOT-OF-5-USED-GENU...4!US!-1 and these are new at peilican. I believe it's part no. 901.211.683.00 https://www.pelicanparts.com/catalog/SuperC..._VENTHT_pg3.htm (clamping bolt) it's a 911 part, but there's a lot of crossover. Maybe someone more knowledgable can confirm... |
Str1974 |
Feb 26 2019, 11:13 AM
These are on ebay.... https://www.ebay.com/itm/LOT-OF-5-USED-GENU...4!US!-1 and these are new at peilican. I believe it's part no. 901.211.683.00 https://www.pelicanparts.com/catalog/SuperC..._VENTHT_pg3.htm (clamping bolt) it's a 911 part, but there's a lot of crossover. Maybe someone more knowledgable can confirm... Great, thank you so much. |
sixnotfour |
Feb 26 2019, 11:48 AM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
dont feel bad...
http://www.914world.com/bbs2/index.php?sho...p;#entry2609178 |
Lo-Fi Version | Time is now: 9th June 2024 - 06:49 PM |
