Who makes the best 914-6 GT Fiberglass rocker panels? |
Steve |
Mar 10 2019, 11:52 AM
914 Guru Group: Members Posts: 5,613 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
GeorgeRud |
Mar 10 2019, 11:58 AM
I’m very happy with the fit of the Getty Design ones I installed. I also used the MSDS short rear valence with flared ends.
If you’d like to use metal, you could get the Restoration Design valences and weld on Ben’s (mb911) flared ends. Obviously much more work than using the fiberglass ones, but would have the best fit as the flares could be matched precisely to your flared fenders. |
Steve |
Mar 10 2019, 03:25 PM
I’m very happy with the fit of the Getty Design ones I installed. I also used the MSDS short rear valence with flared ends. If you’d like to use metal, you could get the Restoration Design valences and weld on Ben’s (mb911) flared ends. Obviously much more work than using the fiberglass ones, but would have the best fit as the flares could be matched precisely to your flared fenders. Thanks George!! Getty is local to me. I will swing by and pick up a pair and save on shipping. |
914Sixer |
Mar 10 2019, 05:19 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
You will probably have to wait for them to be built.
Lo-Fi Version | Time is now: 8th June 2024 - 06:41 PM |
