> 911 front hubs- split washers or no
twistedstang
post Mar 14 2019, 01:48 PM
I'm finishing up my five lug swap and hit a wall. On the aluminum 911 hubs, is it proper to use a split washer on the aluminum hub when bolting on the rotor? If so, should I run the bolt through the hub first so the split washer is on the rotor side instead? I'm worried they will mar the aluminum.
Replies(1 - 5)
yeahmag
post Mar 14 2019, 02:28 PM
I use a flat washer and non-locking 8mm nut torqued to spec.
mb911
post Mar 14 2019, 02:53 PM
I use spring washers no split washers.
sixnotfour
post Mar 14 2019, 03:45 PM
2 900 075 079 02 Hexagon-head bolt 10 914-6
M 8 X 22
3 N 012 241 1 Spring washer 10 914-6
B 8 X 15
4 900 076 025 02 Hexagon nut 10 914-6
M 8
bdstone914
post Mar 15 2019, 03:19 AM
bdstone914
Spring washers are correct. The bolt goes through from the rotor side with the nut and washer against the hub.
Bruce
twistedstang
post Mar 15 2019, 05:33 AM
Thanks everyone. I'll be on the hunt today for spring washers.
- Lo-Fi Version Time is now: 15th September 2026 - 05:23 AM
