Sloppy Windshield Install? |
FlacaProductions |
Mar 20 2019, 03:46 PM
Senior Member Group: Members Posts: 1,615 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Larmo63 |
Mar 20 2019, 03:50 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
It does look like goo splooging through.
Yes, I think that is a topper. |
jdamiano |
Mar 20 2019, 03:54 PM
Member Group: Members Posts: 335 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
Yes it looks like a dash cover. The picture isn’t great but it’s looks like a not great windshield install. You can pull out the rubber seal and clean the mess then replace the seal with one from 914rubber. It will be a messy no fun project. The problem with reinstalling the windshield is removing it without breaking it.
ndfrigi |
Mar 20 2019, 03:58 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Since ur from SoCal, call Rufino who did several windshield installation for 914s.
Rufino’s number (714) 292-5811 |
mepstein |
Mar 20 2019, 03:59 PM
914-6 GT in waiting Group: Members Posts: 19,313 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Dash covers are hard plastic. If you can make a dent with your fingernail, it’s vinyl. You can also feel the hard edge at the ashtray and at the top of the gauges.
FlacaProductions |
Mar 20 2019, 04:33 PM
I'm familiar with the plastic nature of a dash topper I'm just not physically with the car - and I think it does look like this is one. usually around the ashtray is the dead giveaway.
jdamiano - thanks for the tip on pulling the seal. I'd be down for that - but not for pulling the windshield just for this if it's in good shape.... |
jdamiano |
Mar 20 2019, 04:43 PM
I'm familiar with the plastic nature of a dash topper I'm just not physically with the car - and I think it does look like this is one. usually around the ashtray is the dead giveaway. jdamiano - thanks for the tip on pulling the seal. I'd be down for that - but not for pulling the windshield just for this if it's in good shape.... If you decide to pull the seal and it’s the original style make sure you have some picks and a shop vac. Harbor Freight sells some picks that work well. It comes out in a zillion pieces and the metal is a pain to remove. Once it is out and everything is cleaned up the 914rubber one goes in easy. Has to be the 914rubber one. They designed it to be installed with the windshield in. |
FlacaProductions |
Mar 20 2019, 04:46 PM
Cool.
I'm hoping that since the windshield appears to have been replaced (hence, the runaway goop...) a new one is in there and would come out easily....a guy can hope, anyway! |
tmc914 |
Mar 20 2019, 04:59 PM
Member Group: Members Posts: 116 Joined: 24-September 17 From: Lowell, MA Member No.: 21,452 Region Association: North East States |
QUOTE If you decide to pull the seal and it’s the original style make sure you have some picks and a shop vac. Harbor Freight sells some picks that work well. It comes out in a zillion pieces and the metal is a pain to remove. Once it is out and everything is cleaned up the 914rubber one goes in easy. Has to be the 914rubber one. They designed it to be installed with the windshield in. The rubber seal at the bottom of the windshield on the inside looks to be in great shape. That is the one that comes out in a bunch of little pieces if original and you need a pick and vacuum for cleanup. It is easily replaced and I did mine last year. That goop looks like butyl that can be trimmed but will be a pain to get a knife down there to trim up. |
FlacaProductions |
Mar 20 2019, 05:02 PM
Mikey914 |
Mar 20 2019, 05:09 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Looks like it was installed with the seal in and too much goop.
If it's one of mine it will come right out and can be cleaned to reuse. (IMG:style_emoticons/default/biggrin.gif) |
FlacaProductions |
Mar 20 2019, 06:18 PM
perfect.....hope it's one of yours!!
Mikey914 |
Mar 20 2019, 11:37 PM
Judging by how uniform it is and there are no cracks Id say it probably is.
Lo-Fi Version | Time is now: 8th June 2024 - 07:43 AM |
