| larss |
Apr 11 2019, 03:03 AM
Member ![]() ![]() Group: Members Posts: 434 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia |
I have been offered a 914/6 tailshift gearbox for my -72 tailshift 914/4, are there any issues in fiitting it in my car?
/Lars S |
| rgalla9146 |
Apr 11 2019, 05:12 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,943 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
You'll need the 6 linkage from the shifter back.
Gulp. |
| larss |
Apr 11 2019, 05:16 AM
| mepstein |
Apr 11 2019, 05:22 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,545 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
You could switch the tail cone of the 6 trans to one from a four. The 4 tail cone should be very inexpensive.
If it was me, I’d sell the six trans for $$$ and buy a rebuilt side shifter with all the parts needed to convert. |
| Krieger |
Apr 11 2019, 06:27 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,842 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
The only difference between the two is the linkage, 2nd and 5th gear. I'd sell the 6 and pocket the change or build a 5 speed with a limited slip.
| jtf914 |
Apr 11 2019, 07:04 AM
Member ![]() ![]() Group: Members Posts: 428 Joined: 31-December 02 From: Burlington, CT Member No.: 58 Region Association: North East States |
The tail cover is different and you can't use the -6 linkage if you have a -4 because of the engine mount bar.
This pic shows the -6 cover on top and the -4 cover on the bottom. As mentioned above you can swap the covers. Attached image(s)
| rgalla9146 |
Apr 11 2019, 07:37 AM
I have to correct myself. You'd have to change all linkage from just inside the tunnel rearward to the tail cover. Not the optimum or inexpensive way to go. I agree with the others. Sell the 6 trans and convert to a side shifter. Don't forget you'll need a side shift front engine bar. |
| dr914@autoatlanta.com |
Apr 11 2019, 08:27 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
no reason to install it, first of all, having to use the six linkage which is impossible to find, the linkage will not clear the heat exchangers, secondly, the six linkage is not really any tighter than the early vague shifting of the four. Thirdly you can sell the six gearbox to a real six owner for enough to purchase a late transmission and linkage with all of the other parts to make a dramatic update to your car's shifting
I have been offered a 914/6 tailshift gearbox for my -72 tailshift 914/4, are there any issues in fiitting it in my car? /Lars S |
| SirAndy |
Apr 11 2019, 11:00 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,460 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
you can sell the six gearbox to a real six owner for enough to purchase a late transmission and linkage with all of the other parts to make a dramatic update to your car's shifting (IMG:style_emoticons/default/agree.gif) |
| larss |
Apr 11 2019, 11:20 AM
Thanks all for responding!
You could switch the tail cone of the 6 trans to one from a four. The 4 tail cone should be very inexpensive. --- So iIf I switch to a tail cone from a 4 I can still use all the linkage as I have it now (tail shift 4 linkage) on the 6 gearbox. /Lars S |
Apr 11 2019, 11:39 AM
also the six transmission has a different ring gear and pinion to deal with the engine power curve, bad bad bad idea to thy to install it on a four, very bad
Thanks all for responding! You could switch the tail cone of the 6 trans to one from a four. The 4 tail cone should be very inexpensive. --- So iIf I switch to a tail cone from a 4 I can still use all the linkage as I have it now (tail shift 4 linkage) on the 6 gearbox. /Lars S |
| oldie914 |
Apr 11 2019, 11:52 AM
Member ![]() ![]() Group: Members Posts: 119 Joined: 2-May 10 From: Germany Member No.: 11,680 Region Association: None |
Change the nose cone to 914/4 and it will work. I have a 914/4 nose cone I would sell you or exchange for the 914/6. I live in Germany so shipping is not so expensive.
That said, you would probably be better off to find a 914/4 transmission or fix yours. |
| larss |
Apr 11 2019, 11:53 AM
also the six transmission has a different ring gear and pinion to deal with the engine power curve, bad bad bad idea to thy to install it on a four, very bad Thanks again, no this is no longer likely to happen just want to know what the alternatives would mean. I have a 2056 in my car with 2.0 D-jet, runs nice, should this engines power curve be so far from the 2.0 110hp six that the trans was geared for? /Lars S |
Apr 11 2019, 12:06 PM
yes
| davep |
Apr 12 2019, 11:23 AM
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,359 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I believe you are mistaken there George. The 914/4& 914/6 transmissions all had 7:31 pinion and ring gears, with the exception of the Sportomatic versions with 7:27 ratio. The 7:31 was common to most 911 & 912 transmissions with only a few exceptions until about 1975 when the 8:31 began to supplant it. The 6:29 ratio for the 1969 912 was considered very weak.
Apr 12 2019, 12:03 PM
Dave you are certainly right, I was thinking of the gear ratios that are different for some of the gears, the sportomatic has the different ring gear and pinion ratio. Thanks for the clarification
I believe you are mistaken there George. The 914/4& 914/6 transmissions all had 7:31 pinion and ring gears, with the exception of the Sportomatic versions with 7:27 ratio. The 7:31 was common to most 911 & 912 transmissions with only a few exceptions until about 1975 when the 8:31 began to supplant it. The 6:29 ratio for the 1969 912 was considered very weak. |
Lo-Fi Version | Time is now: 17th March 2026 - 02:33 PM |
