> 3" spacing caliper upgrade project, Wilwood Forged Dynalite Calipers?
1970-1914
post Apr 11 2019, 04:43 PM
I ended up picking up a new set of these calipers for almost nothing so I am going to see if I can make an adapter to mount them on my 3" spacing Boge 911 struts.
These are 5.25" bolt spacing and are listed to work with the 911 rotor thickness and diameter.
No guarantee this will work but we will see....
Replies(1 - 4)
roblav1
post Apr 11 2019, 05:12 PM
I don't see it happening. Unless there's enough offset to allow material between the 5.2" spacing and the 3" spacing. Hard to tell in the pics, but it doesn't look like you'll have it.
Mark Henry
post Apr 11 2019, 07:08 PM
that's what I do!
Contact Flat (Lanner), I think he lives in Fort McMurray now, he's a master at adapting calipers.
He also makes a kickass carb cable linkage kit.
http://vdubengineering.com/brake-parts-kits/
post Apr 11 2019, 07:55 PM
QUOTE(Mark Henry @ Apr 11 2019, 06:08 PM) *
Thanks for the recommendation but I want to try fitting this myself. Barring the steering arm or stock mount physically blocking the caliper placement/offset it should be be pretty straightforward. I have access to pretty much anything required to make a set of adapters (Solidworks, cnc mills/lathes/plasma tables, mig/tig etc) as well as some pretty clever guys. (IMG:style_emoticons/default/driving.gif)
wndsrfr
post Apr 11 2019, 08:12 PM
Check out this thread....my Wilwood conversion is detailed somwhat in post #20....go for it, it's not rocket science. Beware that you'll need an adapter for the brake line since the Wilwood uses non-metric threads.
http://www.914world.com/bbs2/index.php?sho...&hl=wilwood
- Lo-Fi Version Time is now: 12th July 2025 - 11:09 AM
