Microsquirt question, Before it blows up! |
Beebo Kanelle |
Apr 29 2019, 04:05 PM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
This may be a stupid question, BUT...
Has anybody run a Microsquirt directly utilizing the 914 board? Using the stock relays for power and fuel pump control? Or, is this the norm? The Megasquirt has its own separate relay board... But I'm now trying to do away with that. Thanks, Dan Noyes |
VaccaRabite |
Apr 29 2019, 09:06 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I’m doing that right now. The Microsquirt uses the stock 914 relay board, though there is different wiring and an added fuse block.
Zach |
falcor75 |
Apr 29 2019, 09:38 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I'm using another brand of ECU but I'm also using the stock relay board for powering up the ecu and the ecu controls the fuel pump relay.
JamesM |
Apr 29 2019, 11:00 PM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
YUP! Been running this way for 15+ years and various Megasquirt and Microquirt board versions. Cleanest way to go in my opinion. Microsquirt activates the FP relay in the same manner d-jet does (grounds the circuit to activate) so that wire is just a direct connection. ECU and Injector power can be pulled from the relayed 12V pin on that same 4 pin connector however you will want to add inline fuses for those.
There is one non critical but slightly annoying issue I have encountered on a couple cars wired this way where for some reason the main relay stays activated when turning the key off until some other load is placed on the electrical system (stepping on the brake, etc) I havent dug to far into it yet as it isnt critical to operation but looks possibly like voltage back-feed though the alternator light as pulling the bulb deactivates the relay. Read a similar issue that BMW guys were encountering where installing a diode on the alternator light circuit fixed the issue. May give that a shot. Just something to be aware of. This may be a stupid question, BUT... Has anybody run a Microsquirt directly utilizing the 914 board? Using the stock relays for power and fuel pump control? Or, is this the norm? The Megasquirt has its own separate relay board... But I'm now trying to do away with that. Thanks, Dan Noyes |
Matty900 |
Apr 29 2019, 11:28 PM
Senior Member Group: Members Posts: 1,269 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
Best tip I can give you from my experience is to add service loops. Especially on your power wire coming out of the microsquirt plug. And leave some room between the plug and the start of your shrink wrap. I ran my car 1700 miles before developing a Gremlin in the wiring. The power is pin 1 if I recall. It is on the end of the plug. With the shrink wrap too close it was putting pressure on the female connector. After vibrating around for 1700 miles, the female connector started to loosen up (insert dirty jokes here) The problem that this caused, was the microsquirt would loose power for a nanosecond as it was running. This would then cause the system to think that the car was not running and it need to go the the startup sequence. Over fueling and more damaging, over dwelling the wasted spark and cooking it. Hope that helps you avoid a potential headache. (IMG:style_emoticons/default/beerchug.gif) Matt |
Lo-Fi Version | Time is now: 8th June 2024 - 10:45 PM |
