FS: NOS 1972 Engine Relay Board Harness $199 shipped, 914 612 007 13 SOLD |
914Sixer |
May 4 2019, 11:39 AM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Nothing better than NOS. Get all new wiring for your engine. This has the additional plug for the blower motor that mounts to the engine tin. $199 shipped
PP: a914nut@email.com Attached image(s) |
burton73 |
May 4 2019, 02:27 PM
burton73 Group: Members Posts: 3,539 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Mark,
You have so much cool stuff. Bob B |
sixnotfour |
May 4 2019, 11:39 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
WOW
JeffBowlsby |
May 5 2019, 08:45 AM
914 Wiring Harnesses Group: Members Posts: 8,527 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Mark 007.13 is 1972-only, and i suspect it was a superseded part for the original 1970-71 harness. PET is not clear on this harness.
007.10 is 1970-71 - if'n you had 007.10, it would be on its way to me... (IMG:style_emoticons/default/smile.gif) The 70-71 version includes a wire for the oil temp sender, that's the only difference. No biggy really, the harness would work on 1970-72 1.7L cars. |
914Sixer |
May 5 2019, 05:35 PM
Jeff,
Thanks for clearing this up. I went by the PET on what is correct. I miss the old paper catalogue. I think is does have the oil temp sender wire. It has green/red stripe wire in the sleeve with cylinder head temp plug. Other sleeve has black/ purple stripe and black/red stripe. The green brown is for the heater. What has me baffled is the spare ground wire. |
JeffBowlsby |
May 5 2019, 05:46 PM
Oil temp wire would be green/black. It was on the 1970-71 harnesses.
Greed/red is oil pressure White is AAR valve Black/purple & Black/red is coil Green and Brown are for the heater fan connection and the piggyback ground wire is what grounds the heater fan to a single male spade found under a screw on the fan housing. |
914Sixer |
May 5 2019, 06:31 PM
Thank you for the correct wiring information. (IMG:style_emoticons/default/smilie_pokal.gif)
914Sixer |
May 19 2019, 04:41 PM
Reduced to $249. Needs to go to good home.
914Sixer |
Jun 8 2019, 08:52 PM
Needs to go. Reduced $199 shipped. Less than a reproduction.
914Sixer |
Jun 26 2019, 09:31 AM
914Sixer |
Jun 26 2019, 10:57 AM
Sold to Pete
Lo-Fi Version | Time is now: 3rd June 2024 - 08:22 AM |
