> Is this the right Bellcrank Carb Linkage, ..so many varieties
Literati914
post May 10 2019, 03:58 PM
Is this the bellcrank carb linkage (IDF) for 914s w/ a normal type 4 fan housing? The thing is.. it specifies the 911 fan, or if looking at the CSP website- it references as being for a 'Porsche fan' and I can not find any other type 4 models for a normal fan.
https://www2.cip1.com/ProductDetails.asp?Pr...129%2D941%2D400
What about the bracket for throttle cable?
Replies(1 - 10)
rhodyguy
post May 10 2019, 04:03 PM
Sounds wrong for us unless you have the 911 fan. Buy with confidence from Mark at Original Customs. In member vendors.
Literati914
post May 10 2019, 04:42 PM
How is it possible that CSP's own website is showing a 911 fan variety for a Type IV but not for a regular fan! That makes no since. Fewer people are going to have invested the significant amount of money to get a 911 fan on a type4 than would have a normal fan. I thought it could mean perhaps, that it would work for both. Cip1 has a sale plus no tax and shipping, so I was hoping they'd have the correct item. BTW before posting this thread I looked at Original Customs to compare prices, and saw nothing listed... another attempt found a note that the store was temporarily closed.
porschetub
Hhhhmmm,not sure ,I have seen these on conventional 914 motors,they are very good and well made ..sharp price too.
I don't see what would make it different as the bellcrank mount bolts to the same point on the T4 case,maybe there is an offset issue?,send them a question on their site,they are pretty good that way.
Don't confuse these with the setup that Raby and Tangerine make,its all rather different and works in another way but better.
Good luck.
Mark Henry
post May 10 2019, 11:18 PM
that's what I do!
CSP is a german shop, peeps there like the porsche fan for the T4 bug conversion. This fits both a 911 shroud and stock suitcase engine.
Tbrown4x4
post May 10 2019, 11:30 PM
That's the one I have. I also ordered the return springs. There are two styles and I can't remember which one I used, but it was only $5 or $6 each, so I bought both.
The cable holder I bought from Original Customs.
Literati914
post May 11 2019, 03:28 PM
QUOTE(Tbrown4x4 @ May 11 2019, 12:30 AM) *
Wait, it has an internal flat spring, right? Sits under the diamond shape top piece?
bbrock
post May 11 2019, 07:15 PM
QUOTE(Literati914 @ May 11 2019, 03:28 PM) *
The spring is optional and has to be ordered separate. I think the spring is offered to compensate for weak carb springs or provide a stiffer pedal feel if that is your preference.
Tbrown4x4
post May 12 2019, 01:50 AM
Correct. I ordered the springs (there are 2 variations, and I couldn't tell from the description which one was needed) because I was (and still am) have problems returning to idle. I thought the extra spring would help. It didn't, but I still have the spring installed. I like the feeling of resistance it provides.
McMark
post May 12 2019, 06:15 AM
914 Freak!
@Literati914 , The one you linked to is the correct one. I clicked through and looked at the other options to be sure. You picked the right one in the first post.
There isn't a spring that works with our direction of rotation. @Tbrown4x4 , if you have one of those installed, take it off -- unless you're absolutely sure it's pulling the throttle closed. But I looked at a lot of options and could never find spring that was compatible. The 914 is the only car that has the accel cable come from the fan side of the engine. So we're the odd-man-out. If you NEED help making the carbs close, add helper springs at the throttle shaft, one on either carb. Make sure the springs are exactly the same and installed in exactly the same way to ensure equal action. BUT if you're having trouble returning to idle, you need to inspect and address the following places, and you must do ALL of them because their resistance is additive -- one may not be a problem on its own, but all together they become sticky.
-Throttle Pedal: If it's not new, maybe it's time. The rubber around the base hinge is intended to aid in throttle return. If it's torn, it can't do that. The hinge itself is meant to move freely and without wobble. If it's rusting inside, it'll add resistance.
-Pedal Cluster Bellcrank: If those little bushings are worn, they can add resistance. They need to be clean, greased, and unworn.
-Throttle Cable: Make sure it's not twisted around the clutch cable first of all. And the most common issue I see with throttle cables is where they protrude from the firewall under the engine. If this area gets even slightly, imperceptably kinked it'll cause a problem. If the steel tube-guide pops off, it's done for -- even if you push it back into place. Now I always pull the steel tube-guide bit off the body accel tube at the firewall when removing the engine specifically to avoid this type of damage to the cable. If in doubt, replace it.
- Throttle Cable Tube: The center tunnel guide tube can have rust in it, can have wear marks, can be bent or broken. The front few inches is the most critical. If that has broken off and been repaired poorly, it can cause a tight spot. That tight spot will increase friction and will quickly erode any plastic liner or even the tube itself. If there's a groove for the cable to sit in, it will increase resistance to movement.
- Throttle Shafts: Finally, the throttle shaft in carbs can be sticky as well. Disconnect your linkage and feel for any sticky action. They should snap closed on their own when released quickly. AND they should move closed of their own accord when gently and slowly returned to closed. And stickiness in this motion will add to the resistance.
It's a bit blunt I suppose, but every piece from your foot to the carbs needs to be moving 100% within spec in order for the throttle to operate like it should. This is the 'trick' for old cars. You simply can never ever assume anything is as it should be. Even if it 'seems okay'. Adding closer springs to the carbs or the linkage are really just band-aids. Springs can cover it up, but the true problem is in all the other pieces.
Tbrown4x4
post May 12 2019, 09:26 PM
Hi Mark, I sent you a PM
- Lo-Fi Version Time is now: 22nd September 2026 - 05:06 AM
