> Dash Gauge Pod, Idea
RolinkHaus
post May 15 2019, 05:35 PM
Looking to create an Audi style dash gauge pod. Has anyone tried this? Did a Google search with no luck. Not a fan of pillar mounted gauges. Probably going with Battery / Oil Temp / maybe a clock...or Cylinder Head Temp. VDO gauges, of course. (IMG:style_emoticons/default/piratenanner.gif)
Replies(1 - 19)
Superhawk996
post May 15 2019, 06:42 PM
I'll bite. Why?
With ready availability of the center console that works and looks great I don't suspect you'll find what you're looking for for the 914 though you could certainly make one.
Simple Path: You can make a custom face for console and fit many more than the stock 3 gauges (clock, oil temp, voltmeter).
Superhawk996
post May 15 2019, 06:43 PM
I'll bite. Why?
VaccaRabite
post May 15 2019, 07:05 PM
En Garde!
There is a gauge plate that covers the stock radio location on the market that holds 3 two inch gauges. I have oil temp, head temp, and oil pressure there.
Clock and volt meter are on the A pillar in the pods.
I don’t run the center console as my feet get stuck on it. I like the extra space without it.
Zach
malcolm2
post May 15 2019, 07:26 PM
VDO stopped making the CHT.... so if you're going for pretty, they won't match. I like the "deposit box" the 3 gauge thing wastes so much space. So I bought 2 VDO type 2 hole "L" brackets and put them under the dash and at the top of the deposit box. Very functional. A/F OT OP CHT
Superhawk996
post May 15 2019, 07:27 PM
QUOTE(VaccaRabite @ May 15 2019, 09:05 PM) *
Zach
I like it, but then what do you do for tunes. If you have a six then I understand . . . That is the best music!
Porschef
post May 15 2019, 07:52 PM
How you doin'
QUOTE(malcolm2 @ May 15 2019, 09:26 PM) *
VDO probably stopped making their CHT because there’s a far better option out there.
Zach, a simple reconstruction of the back of the center console opens up a world of extra room; I’m a size 11 and no longer have any issues with my foot getting stuck. That said, I like the look of the no console.
But where would I put all the gauges? (IMG:style_emoticons/default/happy11.gif)
bob164
post May 16 2019, 12:58 AM
A friend wanted to add three gauges that would be in his field of view, not down below the dash. He did the basic aluminum shape and I did the welding and wiring. It has VDO oil pressure, oil temp and voltage gauges and also a USB port. It appears to be mounted a little low, but when in the driver's seat you can see the entire range of each gauge.
And yes, he has a sense of humor.
RolinkHaus
post May 16 2019, 02:20 AM
Not a fan of the center console myself. I will do some experimentation, posting pics. In the mean time, added a side mirror. Some will like it, others will not.
RolinkHaus
post May 16 2019, 02:35 AM
Love the Vitaloni Sebring mirrors, but in order to see behind, placement is key. Still experimenting.
VaccaRabite
post May 16 2019, 07:46 AM
En Garde!
QUOTE(Superhawk996 @ May 15 2019, 09:27 PM) *
70 watt amp hidden under the dash, with a hardwired minijack run to the center armrest compartment that I can plug my iphone into. Easy! Volume control is all done through the iPhone.
At least that was what I did until I pulled it all out when I realized I wasn't using it. I tend not to listen to music in my 914.
Zach
campbellcj
post May 16 2019, 09:18 AM
I can't Re Member
FWIW I ran the 3-gauge VDO radio slot setup for a few years and it did look nice and function fine, but I found it undesirable to divert attention to look at them. I went to the quad-gauge in the standard dash location; a triple gauge would've been fine/better in hindsight. (Voltmeter is pretty useless.)
jrblackbox
post May 16 2019, 09:25 AM
QUOTE(VaccaRabite @ May 15 2019, 06:05 PM) *
Zach
I want to rid myself of the center console too. Where can I find this gauge plate that covers the radio location?
dr914@autoatlanta.com
post May 16 2019, 09:29 AM
reminds me of the old amco console, Jeff bowlesby may have a picture of one installed. Has an armrest and a guage pod that sort of looks like the Audi pictured
QUOTE(RolinkHaus @ May 15 2019, 04:35 PM) *
malcolm2
post May 16 2019, 09:48 AM
Not installed, but you get the idea. I would love to find one of these.... I have 4 gauges tho. Don't remember seeing one with the rectangle gadget with the LCD. Wonder what that is. Plus are the rocker switches usually used for seat heaters or power windows?
thelogo
post May 16 2019, 09:55 AM
Group: Retired Members
Cant remember who has it
But id toss all those guages and just get the
Fuel guage that has a huge red oil light.
Size of entire guage i think
Do you really need more then that .
7TPorsh
post May 16 2019, 10:45 AM
7T Porsh
I did the dash....Ferrari 250 GTO style
7TPorsh
7T Porsh
dupe post
malcolm2
post May 16 2019, 10:56 AM
QUOTE(thelogo @ May 16 2019, 10:55 AM) *
But id toss all those gauges and just get the
Fuel gauge that has a huge red oil light.
Size of entire gauge i think
CHT and OT has caused me to check around. A full size paper towel had been sucked into the fan and was covering 1/3 or 1/2 of the fins. OT went up to 260 on a 80* day. I knew something was wrong. CHT needle does not move as far for a 20* increase, but I noticed a change.
another time, my ALT light came on on a 3 hour interstate trip. The voltage gauge assisted in how close I could get to home before shutting it down..... 8.5 volts as I pulled into a Cracker Barrel parking place.... 45 minutes from home.
For some people they are nice to have, some look nice, and I enjoy the feedback. To each his own.... like brands of oil, tires, etc....
VaccaRabite
post May 16 2019, 11:05 AM
En Garde!
QUOTE(jrblackbox @ May 16 2019, 11:25 AM) *
I got mine a few years back from RennMetal ( I think). But its just a flat sheet of steel with three 2 1/16th inch holes in it. You could make one yourself in just a few minutes with a 2 inch hole saw and some 18 or 16 ga stock steel from your local hardware store. Super simple design.
Zach
- Lo-Fi Version Time is now: 4th July 2025 - 03:00 AM
