442nd914s |
Member ![]() ![]() Group: Members Posts: 139 Joined: 25-July 12 From: KC Suburb Member No.: 14,718 Region Association: None ![]() |
I never noticed this before until the body shop went to check the fog lamps after replacing the old ones.
We noticed that the fog lights only come one when the brights are on. From my understanding, the fog lights should only come on with the dim lights.....is that correct? All of the rest of the lights operate normally. With the exception of 2 dash lights......the hi beam indicator light on the tach and parking indicator light on the speedo. Could it be coincidental that the bulbs might be burned out OR tied into my fog lamp problem? I've tried researching a good 73 wiring diagram and have zero luck. I did notice that my 3rd peg connection behind the fuse box is missing a wire connection. Oh and all my relays on the fuse panel work. So what gives? (IMG:style_emoticons/default/confused24.gif) Thanks for yall help P.s. I know that the hi beam indicator lamp comes after the hi beam fuse but where and color is unknown. |
Lo-Fi Version | Time is now: 15th July 2025 - 05:49 AM |
