Idle speed drops when clutch engaged |
David Mueller |
Jun 25 2005, 04:23 PM
Member Group: Members Posts: 79 Joined: 4-February 03 From: Calgary, Alberta Canada Member No.: 236 |
Really weird things going on. Car idles just fine when sitting but as soon as I engage the clutch even if I'm in neutral then the idle drops down. Does anybody have any ideas ?
SpecialK |
Jun 25 2005, 04:40 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
This is a total WAG, but might it be a throw-out bearing that's gotten stiff causing a rotational load on the pressure plate? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Can't think of anything else off hand that would cause such a condition.
Edit: I noticed down the page a bit a post with a similar condition, it appears that his arm was rubbing the pressure plate....well, it's something else to check at least. |
qa1142 |
Jun 25 2005, 04:44 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
Clutch tube loose in tunnel and cables hitting each other? (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
type47 |
Jun 25 2005, 05:02 PM
clutch cable and throttle cable tangled?
Lo-Fi Version | Time is now: 4th June 2024 - 01:15 PM |
