> 914/6 ignition switch woes, won't engage starter
rudedude
post Jun 11 2019, 07:49 PM
For a few years now the switch in my /6 has been declining in its ability to get past the run position to the start position. It can take upwards of 10 tries to engage starter. I finally ordered a new electrical portion believing that to be the issue. Now that i have the electrical part removed I see that the issue is in the mechanical part. Has anyone had one apart to see if they are repairable? Its now gone to a much more difficult fix removing shear pins and the switch than just the easy fix. Any help is much appreciated.
Thanks,
Jule
Replies(1 - 6)
914Sixer
post Jun 12 2019, 06:31 AM
Maybe Dan can fix it for you. Sounds like it is just worn out. Replacements are in the $800 range.
bdstone914
post Jun 12 2019, 08:06 AM
bdstone914
@914Sixer
[/quote]
@TWEET
Dan, can you work on a 911 ignition switch?
@rudedude
Jule,
You can try Pelican 911 parts forum for a used one.
Bruce
rudedude
post Jun 12 2019, 10:01 AM
I spoke with porsche dealer as this is supposedly a special order, ? keyed to your vin. Is it possible to change the tumbler assembly on a used one? Or am I stuck going with porsche? It is the same ignition interlock that is used in 911 up thru 98 I believe.
Thanks,
Jule
mb911
post Jun 12 2019, 10:49 AM
QUOTE(rudedude @ Jun 12 2019, 08:01 AM) *
Thanks,
Jule
Tweet can do it. He did mine took a while but he was rekeying everything and he was very busy. Make sure you call and talk to him.
sixnotfour
post Jun 12 2019, 11:25 AM
https://www.ebay.com/str/Type-4-and-More?_pgn=2
rudedude
post Jun 12 2019, 08:25 PM
Thanks, I'll get ahold of him
- Lo-Fi Version Time is now: 16th September 2026 - 01:34 AM
