Ground Strap and Front Wheel Bearing Grease Question, Strap Length and Grease Recommendation |
Highland |
Jun 23 2019, 07:35 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
Just like the title says:
- Can anyone tell me the transmission ground strap length? Is it more than 8 inches? - Will Swepco Moly 101 work on the front wheel bearings? |
Mikey914 |
Jun 24 2019, 10:14 AM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
9-1/4" is what I recall from memory.
90quattrocoupe |
Jun 24 2019, 02:36 PM
Member Group: Members Posts: 208 Joined: 4-November 16 From: Long Beach, CA. Member No.: 20,561 Region Association: Southern California |
Swepco 101 moly works just greatl
Greg W. |
bbrock |
Jun 24 2019, 03:19 PM
The ground strap I have measures 7 inches.
Spoke |
Jun 24 2019, 03:36 PM
Jerry Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Mikey914 |
Jun 24 2019, 10:42 PM
I think you could use shorter, but it may be a little harder to install. Not saying you can’t.
Chi-town |
Jun 25 2019, 08:31 AM
jcd914 |
Jun 25 2019, 02:32 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I started using Swepco 101 for wheel bearings some 25+ years ago and never had a problem.
I use it for CV as well and most anything else I need grease for. Jim |
porschetub |
Jun 25 2019, 02:45 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
My ground cable was made out of a piece of heavy 200amp welder cable with sealed crimped copper eyelets,its totally sealed then ,my old original on was all crusty and stiff I didn't want to use it.
Rand |
Jun 25 2019, 02:47 PM
Rule of thumb.... Or other reference. Ploob. Last. Last my man, last.
Mark Henry |
Jun 25 2019, 02:48 PM
Been using it for years no issue.
For Ford moly is the only recommended grease for it's wheel bearings. |
rudedude |
Jun 25 2019, 03:26 PM
Senior Member Group: Members Posts: 511 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
New strap I got from Stoddard is only 7" long, 6 1/2 between holes.
Lo-Fi Version | Time is now: 11th June 2024 - 02:23 AM |
