alexkirkham |
Newbie ![]() Group: Members Posts: 17 Joined: 23-April 18 From: London, UK Member No.: 22,066 Region Association: None ![]() |
Hi everyone,
I'm really keen on running some soft-ish front koni reds in may standard 914 1.7 with boge struts (the bumps are giving me too much feedback with the bilsteins)... so, are the 911/912 koni reds, as in : https://www.carnoisseur.com/products/detail...ASABEgIv2vD_BwE interchangeable? I suspect not: possibly a different length? any wisdom on this or alternate struts gratefully received! thanks alex |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,892 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
IIRC the boge struts support both the Bilstein and the Koni Shocks. I have boge struts and was running koni’s and I switched to Bilstein. I am running 911, 3.5” boge struts.
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
The 911 inserts will fit the 914 boge struts as long as they are not specifically for the 911S that came with the Koni Struts.
The valving is for the 911 which is a heavier vehicle and may not be optimal for the 914. I have always found the Koni shocks more comfortable than the Bilstein shocks, even Koni sports. YMMV Jim |
Lo-Fi Version | Time is now: 15th July 2025 - 03:25 AM |
