WT B: speedo |
WT B: speedo |
StratPlayer |
Aug 3 2019, 11:51 AM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Looking for a late model speedo in good working order.
Looking for the 150 mph one |
914Sixer |
Aug 3 2019, 07:47 PM
914 Guru Group: Members Posts: 8,898 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Might have one, will have to test.
Chi-town |
Aug 3 2019, 10:33 PM
I have one
914Sixer |
Aug 4 2019, 02:10 PM
Both the ones I have only the speedometer works. No mileage or trip reset.
914forme |
Aug 4 2019, 06:10 PM
Easy fix if you want to fix it, fun in an odd sort of way. Speedogears has what you need, and then it is all mechanical. Some times the gear just slips on the shaft, some times it is broken and brittle. The plastic that VDO used did not like the lubricant they used. They will all die eventually, even if they have sat in a time capsule.
Not sure about if you launched one into space, the cryo temperatures do so odd things to materials. |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:42 PM |
