rear axle bushing replacement what about nuts and washers, difference between the PET and my car |
CheeRS |
Aug 20 2019, 08:53 AM
Member Group: Members Posts: 93 Joined: 5-May 19 From: Paris France Member No.: 23,093 Region Association: France |
Hello, I took advantage of a motor problem (other post) to inspect my 914 in details.
I realized that I needed more than 4mms shims to have a camber around 2 °, I had concluded that the silent block of rear train were tired. So I took my arms off and changed the rubber. My question is about washers. On PET, there are 4 nuts but only 2 washers for the 2 sides. Is there washers between the body and the axle ? or only under the nuts ? Thanks CheeRS from Paris |
CheeRS |
Aug 20 2019, 08:56 AM
on the PET only one washers by side,
mistake ? Attached thumbnail(s) |
CheeRS |
Aug 20 2019, 08:57 AM
found washers both sides
CheeRS |
Aug 20 2019, 08:58 AM
new bushes
CheeRS |
Aug 20 2019, 09:00 AM
the pet
Mikey914 |
Aug 20 2019, 09:15 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The one washer is correct.
On another note something looks off on the rubber bushing. The shaft is not centered or the bushing is too tall. Also bead blast the shafts while you have them out. The factory are notorious for having pin holes that water can get it. Now if the perfect time to check this. (IMG:style_emoticons/default/beer3.gif) |
CheeRS |
Aug 20 2019, 09:28 AM
thanks
washer under the nut only one side (interior) ? Rubbers are theses ones https://www.rosepassion.com/fr/cat/porsche-...n-route/P111811 |
Lo-Fi Version | Time is now: 7th June 2024 - 10:40 AM |
