doug_b_928 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 716 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada ![]() |
I'm going to need a new front bumper top from 914Rubber, but I'm hoping to save the rear one. It's in really nice shape but it looks dirty, dull/faded (see pic below). What's the best way to bring it back to looking its best?
Mike Fitton |
Senior Member ![]() ![]() ![]() Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest ![]() ![]() |
I have had luck with 150, 400, 600 sand paper then “back to black”.
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,992 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Wash with dish detergent then Vaseline and leave it in the sun for a bit. Buff with soft cloth.
doug_b_928 |
Those are two interesting, and quite unique, approaches. I’ve previously used back to black and it has worked well initially but not held up very well. But that was on a harder material. Would the Vaseline method last longer?
mepstein |
Those are two interesting, and quite unique, approaches. I’ve previously used back to black and it has worked well initially but not held up very well. But that was on a harder material. Would the Vaseline method last longer? Depends if it's a garage queen or daily driver. Just re-apply as needed. If the vaseline doesn't work, you can always sand but might as well try easy, first. |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,982 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Rub glycerin into it. It requires reapplication from time to time, but its not petroleum based so it will not deteriorate the rubber.
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Hot water and soap. Wipe with acetone. Shoot with penetrating vinyl dye.
You should keep most of the texture. Really a matter of cleaning opening up any pours, and the vinyl dye will make it a satin color. This is if the rubber is not too far gone. If it’s wavy the internal structure is failing. You can still use it, but it’s a matter of time. Thanks, Mark |
gereed75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,373 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States ![]() ![]() |
Great tips guys. Not sure it is needed in this instance, but I did a pretty effective repair using black 3M 5200 adhesive. This stuff would definitely work to secure new anchors too. http://www.914world.com/bbs2/index.php?sho...=240803&hl=
With some diligence it might be possible to reskin a bumper top with a “ skim” coat of this stuff. Maybe?? |
doug_b_928 |
Thanks to all for the ideas. I’ll weigh my options. I don’t see the VHT vinyl dye locally but I do see Duplicolor vinyl and fabric paint. Does anyone know if that’s the same as vinyl dye (i.e., is vinyl dye a paint)?
Gatornapper |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,280 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States ![]() ![]() |
After the sanding, one of the best detailers on the east coast who is a friend says this is the best stuff there is:
https://www.amazon.com/Solution-Finish-Blac...2dDbGljaz10cnVl GN |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,757 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
She cleans up nicely. Touch up your valence covers and tires and it will "pop"! (IMG:style_emoticons/default/beerchug.gif)
Mikey914 |
Great tips guys. Not sure it is needed in this instance, but I did a pretty effective repair using black 3M 5200 adhesive. This stuff would definitely work to secure new anchors too. http://www.914world.com/bbs2/index.php?sho...=240803&hl= With some diligence it might be possible to reskin a bumper top with a “ skim” coat of this stuff. Maybe?? Yes it is possible to “Reskin”, difficult to get the texture correct. The problem is that with vibration and heating and cooling cycles it will separate as the base material is over 45 years old and even if glued, will come apart. Maybe you get a year or two, but eventually it will fail. But hey you got an arts and crafts project to keep you busy next weekend. (IMG:style_emoticons/default/biggrin.gif) |
gereed75 |
Not sure about skimming but I did that “chunk” repair five years ago and it still looks like the day I did it.
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,895 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Thanks to all for the ideas. I’ll weigh my options. I don’t see the VHT vinyl dye locally but I do see Duplicolor vinyl and fabric paint. Does anyone know if that’s the same as vinyl dye (i.e., is vinyl dye a paint)? The cleaning and prep is the key to a longer lasting solution,used the Duplicolor and it lasts 3yrs or so if not applied to a clean surface it starts to degrade in about 18 months. The sun here in NZ is rather vicious. I would stick with a product known to be suitable for bumpers,good luck. |
Lo-Fi Version | Time is now: 31st July 2025 - 07:24 AM |
