WTB: 2.7 CIS 6 cyl throttle plate and linkage |
AnthonyM |
Sep 3 2019, 07:05 PM
Newbie Group: Members Posts: 38 Joined: 8-December 12 From: Hudson, OH Member No.: 15,243 Region Association: North East States |
I just recently purchased a 914-6 GT project and started looking over it and it appears I'm missing the aluminum throttle plate and linkage. Anybody have one laying around?
AnthonyM |
Sep 3 2019, 07:07 PM
Sorry....this is a 2.7 CIS 6cyl
Dominic |
Sep 3 2019, 07:57 PM
Dominic Group: Members Posts: 992 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
aturboman |
Sep 3 2019, 08:14 PM
Member Group: Members Posts: 135 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
I should have it. Is it only the lever on the throttle body or the console on the case as well? Should have both
IronHillRestorations |
Sep 3 2019, 10:16 PM
I. I. R. C. Group: Members Posts: 6,729 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I think I've got the bracket and bell crank, but not the short linkage pieces
morgan_harwell |
Sep 4 2019, 08:44 AM
Ha! Finally snuck up on a camera! Group: Members Posts: 126 Joined: 28-January 03 From: Santa Cruz Mtns., Ca. Member No.: 203 Region Association: Northern California |
Reference the photo in post #1:
The engine case mounted 911 CIS throttle plate and linkage in the photo has been modified to use a stock 4-cylinder throttle cable and 'pull' from the front of the 914. An unmodified 911 CIS throttle plate and linkage would 'pull' toward the rear of a 914. That would require a stock 914-6 throttle cable and the 914-6 transmission mounted throttle lever assembly. |
AnthonyM |
Sep 4 2019, 07:54 PM
I haven't posted a WTB ad at Pelican, but as you mentioned it may not be a bad idea. The picture that I posted was a picture that I grabbed from an older 2.7 CSI post. Great point on the modified plate/cable and how it would function. Does anyone have any other ideas on what the set up should look like.
sixnotfour |
Sep 5 2019, 03:47 AM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
you'll also need the spacer that goes on one stud
AnthonyM |
Sep 6 2019, 04:37 PM
Going back through some boxes and found the CIS throttle plate, bracket and bell crank. Thanks for checking!
AnthonyM |
Sep 15 2019, 02:53 PM
Still looking for the throttle rod from the bell crank on the tranny to the throttle plate. Also need the short throttle linkage from the throttle plate to the throttle body.
Lo-Fi Version | Time is now: 8th June 2024 - 04:48 AM |
