> No Lights !
63acornwall
post Sep 10 2019, 10:56 AM
When I operate the light switch on dash nothing happens - no panel lights , no side lights , no headlamps popping up . All worked ok before and will go have a look with a multimeter tomorrow . Suspect switch as there are 6 or so independent fuses protecting individual items and doubt they have all failed at same time .
Hazard lights work off their switch , turn indicators work off their stalk , reversing lights ( backup lights ) work when reversing .
What shall I try ?
Replies(1 - 2)
lierofox
post Sep 10 2019, 12:03 PM
QUOTE(63acornwall @ Sep 10 2019, 09:56 AM) *
What shall I try ?
From what you've described I'd start by checking for +12v battery voltage at Terminal #30 on the headlight switch, which should be fed from the back-side (un-fused side) of fuse #10. Make sure neither of those are loose or popped out.
Might also check Terminal 15 which should have +12v when the key is on.
63acornwall
post Sep 10 2019, 11:57 PM
Thanks for that lierofox , will save a lot of time !
- Lo-Fi Version Time is now: 8th September 2026 - 06:27 AM
