brcacti |
1974 914 1.8 ![]() ![]() ![]() Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region ![]() |
Do I need to take the steering wheel off to take the odometer out, not a real lot of room to pull the odometer off if I don't
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,707 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
brcacti |
Thanks for the information
porschetub |
Also forgot to mention your speedo may be stuck in the surround after being in there for years...mine was,the rubber ring gets sticky,if you can't move it take your fuel/combo gauge out first and then reach your speedo through that opening,helps to undo/refit the drive cable also,good luck.
mlindner |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,533 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest ![]() ![]() |
porschetub, I'll second on the combo gauge out and push the speedo out.
Lo-Fi Version | Time is now: 16th June 2024 - 09:58 AM |
