| 63acornwall |
Nov 7 2019, 08:50 AM
Member ![]() ![]() Group: Members Posts: 53 Joined: 24-January 19 From: London , UK Member No.: 22,823 Region Association: None |
I now have a working VDO clock for the center console but am missing the rubber seal to mount it with .
Hole in console is 80mm diameter , clock is 60 mm diameter . Where can I get the rubber seal from ? breakers yard ?? not sure how to describe it for an ebay search ! |
| ConeDodger |
Nov 7 2019, 08:59 AM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,667 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Rocky Mountains
| yellowporky |
Nov 7 2019, 09:01 AM
Member ![]() ![]() Group: Members Posts: 446 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
914 rubber did not carry in the past but recently Auto Atlanta said that they carry them. I need all 3 center console rings too
| dr914@autoatlanta.com |
Nov 7 2019, 09:35 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,255 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Factory vdo console gauges are 60 and use a rubber sleeve to fit which we now make. Aftermarket vdo are 50 and use a spacer ring to fit into the factory console hole
I now have a working VDO clock for the center console but am missing the rubber seal to mount it with . Hole in console is 80mm diameter , clock is 60 mm diameter . Where can I get the rubber seal from ? breakers yard ?? not sure how to describe it for an ebay search ! |
| 63acornwall |
Nov 7 2019, 10:15 AM
Factory vdo console gauges are 60 and use a rubber sleeve to fit which we now make. Aftermarket vdo are 50 and use a spacer ring to fit into the factory console hole I now have a working VDO clock for the center console but am missing the rubber seal to mount it with . Hole in console is 80mm diameter , clock is 60 mm diameter . Where can I get the rubber seal from ? breakers yard ?? not sure how to describe it for an ebay search ! thanks dr914 , how do I find it on your site ? ( did a search earlier today before I posted but failed to find it ) |
| FlacaProductions |
Nov 7 2019, 11:19 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,303 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
I actually need all 3 for the stock/oem console gauges.
Are all 3 60mm?? Who has 'em - i've looked.... |
| Mikey914 |
Nov 7 2019, 12:04 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,786 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
We make the 100, the 155 for the main gauges and the 80 for the 911 clock,
We can make the 60's also as we do sell the center consul https://900designs-container.zoeysite.com/search/?q=guage |
Nov 7 2019, 12:07 PM
no reason to Mark, we have over 100 in stock
We make the 100, the 155 for the main gauges and the 80 for the 911 clock, We can make the 60's also as we do sell the center consul https://900designs-container.zoeysite.com/search/?q=guage |
| FlacaProductions |
Nov 7 2019, 12:47 PM
show me a link please, George - I ended up asking here because I know @Mikey914 doesn't make them but I've searched 3 different ways on your site and can't come up with them. It shouldn't be that hard....
| mmichalik |
Nov 7 2019, 01:39 PM
MikeM ![]() ![]() ![]() Group: Members Posts: 805 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California
show me a link please, George - I ended up asking here because I know @Mikey914 doesn't make them but I've searched 3 different ways on your site and can't come up with them. It shouldn't be that hard.... if you search for " RUBBER MOUNTING RING 914" on the AA site you should see them. |
| FlacaProductions |
Nov 7 2019, 01:52 PM
Closer. So they’re 80mm for the stock console gauges?
That site is still clear as mud. Maybe I’m slow. |
| Mikey914 |
Nov 7 2019, 01:59 PM
Closer. So they’re 80mm for the stock console gauges? That site is still clear as mud. Maybe I’m slow. 80 is the 911 dash clock And yes we make them (IMG:style_emoticons/default/biggrin.gif) |
| FlacaProductions |
Nov 7 2019, 03:33 PM
@mmichalik - I appreciate the help but if I search "RUBBER MOUNTING RING 914" I get a page that shows me 18 items including 115, 100, 80 and 75mm.
I see no 60mm and the only ones on that page that are indicated to be for a 914 are the 115 and 100's. (IMG:style_emoticons/default/WTF.gif) |
| 63acornwall |
Nov 7 2019, 03:41 PM
@mmichalik - I appreciate the help but if I search "RUBBER MOUNTING RING 914" I get a page that shows me 18 items including 115, 100, 80 and 75mm. I see no 60mm and the only ones on that page that are indicated to be for a 914 are the 115 and 100's. (IMG:style_emoticons/default/WTF.gif) Same thing I found .... |
| FlacaProductions |
Nov 7 2019, 04:00 PM
Good, (I guess?!)
I'm not crazy, then. Anyway - I've had two very nice offers offline regarding acquiring these.... |
| mmichalik |
Nov 8 2019, 09:42 AM
| FlacaProductions |
Nov 8 2019, 09:59 AM
Thanks @mmichalik - no worries - I appreciate the help.
| Mikey914 |
Nov 8 2019, 11:14 AM
Hey George
Waiting on the response on the PM to buy these. You're not gonna make me make them are ya? (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 27th November 2026 - 10:13 PM |
