Power to guages, What supplies this power |
surfdogskier |
Nov 23 2019, 12:18 PM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
I mentioned this before in a thread but I don't think it got answer. Since the tach wire is the only wire is see on the relay board that goes a gauge, is this also responsible for powering the other gauges as well? My gas, speedo, tach, do not work when the car is running.
Right now, if I hook up the purple/black wire coming from my relay plate to the - side of the coil, it causes the car to die. I evidently have a short somewhere in that wire some sort of theft thing installed maybe that is causing this. I am in the process of ripping it out and seeing what I got going on. |
TheCabinetmaker |
Nov 23 2019, 12:26 PM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
To the best of my memory, The tach wire goes on the negative terminal work the condenser wire.
Superhawk996 |
Nov 23 2019, 02:45 PM
914 Guru Group: Members Posts: 5,852 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Whenever you have electrical problems the 1st stop should be to look at the schematic.
Lo-Fi Version | Time is now: 22nd May 2024 - 10:03 PM |
