Head Temp gauge |
Head Temp gauge |
Charles Freeborn |
Jan 3 2020, 08:26 PM
Member Group: Members Posts: 250 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
Opinions? Thermo couple vs ?? Spark plug sender vs NPT... which cylinder? I've got questions!
yeahmag |
Jan 6 2020, 04:53 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Opinions? Thermo couple vs ?? Spark plug sender vs NPT... which cylinder? I've got questions! #3 is the cylinder to watch using the sender that goes under the plug. A Micro 1000 is what I run because it is temp compensated and looks right on my dash. https://www.aircraftspruce.com/catalog/inpa.../CHT_gauges.php In the future I may switch to this (link below) due to some additional features, like alerts: http://thesensorconnection.com/cht-sensors...e-sensor-kit-fs |
GregAmy |
Jan 6 2020, 09:31 PM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
If you're into data acq, this guy has one with a 0-5VDC output. Uses any K type thermocouple.
Might add one of those to the race car... |
Charles Freeborn |
Jan 7 2020, 03:50 PM
Opinions? Thermo couple vs ?? Spark plug sender vs NPT... which cylinder? I've got questions! #3 is the cylinder to watch using the sender that goes under the plug. A Micro 1000 is what I run because it is temp compensated and looks right on my dash. https://www.aircraftspruce.com/catalog/inpa.../CHT_gauges.php In the future I may switch to this (link below) due to some additional features, like alerts: http://thesensorconnection.com/cht-sensors...e-sensor-kit-fs This is the second rec for the aircraft style. One question - thought. How important is the temp compensation aspect in a sea-level vehicle? I understand the need in an aircraft situation where the ambient temps could swing radically, but is that an isusue in a car? Thanks! |
jd74914 |
Jan 7 2020, 04:08 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
This is the second rec for the aircraft style. One question - thought. How important is the temp compensation aspect in a sea-level vehicle? I understand the need in an aircraft situation where the ambient temps could swing radically, but is that an isusue in a car? Thanks! The compensation is actually for the junction block at the back of the unit reading, so in this case you're compensating for cabin (or dash/center console) temperature if mounted there. Without compensation it'll assume something like 68*F temperature, so you could theoretically see errors of +/-30*F depending on cabin temperature. I think it's worth it as that's quite considerable error on a 300*F measurement. |
jd74914 |
Jan 7 2020, 04:12 PM
If you don't care about looks there are a bunch of panel mount industrial display options which run on 12VDC and may be cheaper than the "aerospace" stuff. All you need is something that reads Type-K thermocouples.
Charles Freeborn |
Jan 8 2020, 10:53 AM
This is the second rec for the aircraft style. One question - thought. How important is the temp compensation aspect in a sea-level vehicle? I understand the need in an aircraft situation where the ambient temps could swing radically, but is that an isusue in a car? Thanks! The compensation is actually for the junction block at the back of the unit reading, so in this case you're compensating for cabin (or dash/center console) temperature if mounted there. Without compensation it'll assume something like 68*F temperature, so you could theoretically see errors of +/-30*F depending on cabin temperature. I think it's worth it as that's quite considerable error on a 300*F measurement. Excellent. Yes, a 30ยบ error could be fatal to the top end. Thanks! |
Lo-Fi Version | Time is now: 28th May 2024 - 08:11 PM |
