| RustyWa |
Jul 17 2003, 04:25 PM
Working Member ![]() ![]() ![]() Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
For you FI guys.
How quickly should the CHT get up to operating temperature? You know, how quickly from 2.5Kohms @ 68 deg.F to 100 ohms or what ever it is at "operating temperature". I need to test mine again, but I'm wondering if mine is dropping to fast. |
| Anton |
Aug 31 2003, 11:51 AM
Royal Orange ![]() ![]() Group: Members Posts: 161 Joined: 25-March 03 From: The Netherlands Member No.: 473 |
I have exactly the same question. Why?
My 1.8 L-jet was running badly (low and irregular idle, decreased acceleration) the last two weeks in Italy; the typical temperature over there was 36 degrees Celcius (contrary to a modest 20 degrees back in Holland). The temperature gauge was in the (upper) fourth quarter range while it is typical in the third quarter range. I have heard of a too low resistance of TS2 at high temperatures producing a lean mixture. What do you Californian and Florida guys say to this? |
| Anton |
Sep 1 2003, 08:44 AM
Test results of my TS2:
@ 15 deg.Celsius (which is below 68 deg.F) I measured 1.8 kOhm quickly dropping to 50 Ohms after driving for 10 minutes when the oil temperature gauge was still within the first quarter of the scale. I interpreted this as a too low resistance, ie., a worn TS2 and ordered a new one. Hopefully this will correct the low and irregular idle and rough running engine at high engine temperatures. |
| Anton |
Sep 8 2003, 04:45 AM
Adjunct to previous postings:
I put a 1 kOhm potentiometer (electrical resistance) between the old TS2 and its connector; turned it to about 0.3 kOhm (300 Ohm). A 0.2 kOhm value was still too low in MPO. This dramatically improved engine performance; cold and hot starting is better, idle is definitely more regular, and acceleration has improved. What it will do to gas mileage I can only guess... (IMG:style_emoticons/default/rolleyes.gif) Still curious to what a new TS2 will do, but it hasn't arrived yet. I found out that TS2 has a so called NTC or negative temperature coefficient and wears over time so that resistance will decrease. |
Lo-Fi Version | Time is now: 9th June 2026 - 02:25 AM |
