OEM Windshield Glass, OEM vs. Aftermarket replacement |
Str1974 |
Jan 17 2020, 01:12 PM
Member Group: Members Posts: 90 Joined: 23-January 19 From: Dallas Member No.: 22,820 Region Association: Southwest Region |
Hi Guys, another question that you guys might answer for me. I have a cracked windshield and need replacing. Hagerty Insurance says they will replace OEM if that is what I had in my car previously, and aftermarket if that is what I had. I'm not the original owner (have had it 1.5 yrs.).
When I run a google search for Laminted F Kinonglas-Kristall-FIRA/F-HI, nothing pops up. It has a VW stamp on it and still no search results. Have seen pics of same with Audi/VW emblem, but none with only VW. Is this OEM for the 1974 Porsche 914 and where could I get that replacement? Thanks |
mepstein |
Jan 17 2020, 02:53 PM
914-6 GT in waiting Group: Members Posts: 19,309 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Local Porsche dealer can get it for you. Usually around $475.
914Sixer |
Jan 17 2020, 03:29 PM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Original Factory Glass not aftermarkert.
Tom_T |
Jan 17 2020, 06:27 PM
Hi Guys, another question that you guys might answer for me. I have a cracked windshield and need replacing. Hagerty Insurance says they will replace OEM if that is what I had in my car previously, and aftermarket if that is what I had. I'm not the original owner (have had it 1.5 yrs.). When I run a google search for Laminted F Kinonglas-Kristall-FIRA/F-HI, nothing pops up. It has a VW stamp on it and still no search results. Have seen pics of same with Audi/VW emblem, but none with only VW. Is this OEM for the 1974 Porsche 914 and where could I get that replacement? Thanks Send your Insurer that photo with the VW emblem, & some notes that the 914 was built by VW at their VW Karmann Plant in Osnabruck (now again owned by VW/Audi) & that Porsche & VW marketed the 914 as VW-Porsche 914 (maybe a pic of that badge), & that this was one of their Euro OEM suppliers of glass - along with Sigla, Sekurit, etc. which are the current OEM suppliers. Look on your original window sticker (Mulroney label) or Porsche COA to see if it was originally optioned with the tinted or clear windshield, then have your shop order from the Porsche dealer (as Mark said above) or ProSource Glass (see member vendor topic on here of theirs). Have it ordered & by & shipped to the installer, so that they're responsible for any damage to that expensive part. You should probably also order new setting blocks &/or the full windshield trim kit from Porsche too, since the old stuff probably won't come off cleanly at this late date. Hopefully insurance will cover that too if the installing dealer, body shop or glass installer will confirm that it won't come off cleanly - &/or that they'll also need the new setting blocks set & butyl setting tape. Also - this should be in the Garage Forum for better coverage, if one of the Admins can move it for him. (IMG:style_emoticons/default/type.gif) Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
rick 918-S |
Jan 22 2020, 05:04 AM
Hey nice rack! -Celette Group: Members Posts: 20,478 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Also use caution in you selection of an installer. Our windshields are installed with butall tape not urothane. Most all glass installers will use urothane. To remove the trim slide a razor blade between the trim and the frame and cut the plastic retaining clips. Do not use a conventional trim removal hook tool. The windshield trim will bend and be ruined.
Lo-Fi Version | Time is now: 5th June 2024 - 12:02 AM |
