Calwaterbear |
Member ![]() ![]() Group: Members Posts: 207 Joined: 15-November 14 From: United States Member No.: 18,123 Region Association: Central California ![]() |
Ok guys,
back at work trying to bring the 73 4 cylinder back to life. I used the trashed floorboard as a template , and used marine plywood to re-make it. Came out good in my opinion. So I have it back in place, but the plates holding it in place are long gone by the PO - who didn't think retaining removed parts was very important - obviously. I'm not making a concourse car - just want a fun canyon carver I can drive a couple of times a week. so anyone use a wide (fender washer ) as a replacement? if so, was it suitable? alternately if I can find an accurate drawing I can fab one up pretty quick, but i don't have any reference to work off of other that the crummy Black and white photo in a Haynes manual thats as old as the car! and anyone know the dimensions of the bolts? thanks in advance everyone cheers |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
You can use a bolt and washer to hold it down. Nit as fancy as the OEM, but will work.
Also have the pedal stop if you need it. https://900designs-container.zoeysite.com/p...4-pedal-board-1 Attached thumbnail(s) ![]() |
FlacaProductions |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,970 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California ![]() ![]() |
I believe those are pan-head screw M6 X 15 - from my PET catalog - Page 217.
Download a version in .pdf - it's really helpful. https://www.porsche.com/all/media/pdf/origi...914_KATALOG.pdf (this one has different page numbers than mine but you'll figure it out...) EDIT: here's a couple of the plates on ebay: https://www.ebay.com/itm/Porsche-911-912-91...XMAAOSw1ZBUwt8P https://www.ebay.com/itm/Porsche-911-912-91...hAAAOSwwzhZVrs1 |
Calwaterbear |
Thanks guys. at 10 bucks a piece, I believe I will use just a washer. Mikey i do have the pedal stip, I was able to rescue that from the original,
thanks for all the info and the links |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,964 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Thanks guys. at 10 bucks a piece, I believe I will use just a washer. Mikey i do have the pedal stip, I was able to rescue that from the original, thanks for all the info and the links I’m pretty sure I have a couple from the last round of plating. PM me your address and I’ll send you one. $n/c. |
Lo-Fi Version | Time is now: 12th July 2025 - 11:27 AM |
