1.7L to 2056 |
1.7L to 2056 |
sreyemj |
Feb 26 2020, 03:47 PM
Member Group: Members Posts: 87 Joined: 12-January 20 From: SA, TX Member No.: 23,821 Region Association: None |
I have a 1.7L motor in my project 914 that needs to be refreshed and I'm thinking of converting it to a 2056 at the same time. This is a somewhat budget build, I'm on a timeline to get it back on the road this summer and as a student there's no way I can justify buying a 9k kit. After looking through quite a few threads on the subject, I'm considering having the case line bored and checked by Tims ACVW in Kent, WA (or maybe there is someone else in Washington State I should consider?). I would prefer to assemble the engine myself if I have time (depending on the rest of the car), otherwise I'll have it assembled.
FAT/Rimco have a 2056 short block kit including pistons and cylinders for $1800 and 1.7L head exchange with 42x36mm valves for $1600. I'm not sure than includes opening the heads up for 96mm cylinders. The FC 442 camshaft looks to be more for carbs, I'm thinking I may want a different camshaft so I can stay with my stock D-jet. Anyone have any experience or input on the FAT/Rimco kit or heads? Is there another option I should consider at the price point? Short block kit: https://fatperformance-rimco.com/products/t...short-block-kit Heads: https://fatperformance-rimco.com/collection...-heads-exchange |
Nogoodwithusernames |
Feb 26 2020, 05:19 PM
Member Group: Members Posts: 239 Joined: 31-May 16 From: Nor-Cal Member No.: 20,051 Region Association: None |
I have a 1.7L motor in my project 914 that needs to be refreshed and I'm thinking of converting it to a 2056 at the same time. This is a somewhat budget build, I'm on a timeline to get it back on the road this summer and as a student there's no way I can justify buying a 9k kit. After looking through quite a few threads on the subject, I'm considering having the case line bored and checked by Tims ACVW in Kent, WA (or maybe there is someone else in Washington State I should consider?). I would prefer to assemble the engine myself if I have time (depending on the rest of the car), otherwise I'll have it assembled. FAT/Rimco have a 2056 short block kit including pistons and cylinders for $1800 and 1.7L head exchange with 42x36mm valves for $1600. I'm not sure than includes opening the heads up for 96mm cylinders. The FC 442 camshaft looks to be more for carbs, I'm thinking I may want a different camshaft so I can stay with my stock D-jet. Anyone have any experience or input on the FAT/Rimco kit or heads? Is there another option I should consider at the price point? Short block kit: https://fatperformance-rimco.com/products/t...short-block-kit Heads: https://fatperformance-rimco.com/collection...-heads-exchange I'll share some of what I have learned so far from reading through lots of threads while planning and starting my 1.7 stock build, though I'm still a rookie with T4 so take it with a grain of salt. I don't think you'd need a whole kit, you can have better selections of parts and not buy what you don't need if you split it up. You can have your crankshaft reground to the 2.0l spec and source a set of stock 2.0l rods for, I'm assuming, less that brand new ones. You can get all your gaskets from the T4 store (LN Engineering) or Aircooled.net or any number of other sources. Grab a set of AA pistons and cylinders. I don't have any advise on the cam but if you do some reading other people have done the 2056 with D-Jet I just don't remember what they used. |
Dion |
Feb 26 2020, 07:09 PM
RN Group: Members Posts: 2,766 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
I was fortunate to start with a 2.0 block.
Here is what got me to a “2056”. 2.0 case, Original crank, 96mm JE pistons, AA cylinders, "fat" performance cam 413 lift,258 duration, Melling oil pump, 009 distributor with Mallory electronic sensor. My build was under 3K (9 yrs ago pricing) and labor was myself and a friend. Obviously you need a couple more steps to get to the 2.0 mark. An enjoyable engine. You can do it. The cam I used was compatible with d-jet. However mine ran CIS at the time. Good luck with the build, hope you find the time. Good luck with the studying too! |
Chris914n6 |
Feb 26 2020, 08:29 PM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
You can do a 1911 and only need the 96mm P&C. 1.8L heads are a plus. Will work with the Djet with a little MPS tuning. Heck of a lot cheaper for not much less power. The real HP in a 2056 comes from the 2.0L heads.
barefoot |
Feb 26 2020, 08:53 PM
Senior Member Group: Members Posts: 1,279 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
I had my 2L case line bored by John Slack in Olympia Wa. He purchased the new main bearings and did the new bores specifically around the size of these bearings. He also fly cut the cylinder base spigots, and had my crank re-ground to first undersize and did the conversion for tapped oil gallery plugs.
He rebuilds Rolls Royce aircraft engines and I was very impressed with his tooling. He goes by "Jesco Reient" here |
sreyemj |
Feb 26 2020, 10:22 PM
You can do a 1911 and only need the 96mm P&C. 1.8L heads are a plus. Will work with the Djet with a little MPS tuning. Heck of a lot cheaper for not much less power. The real HP in a 2056 comes from the 2.0L heads. I have no idea of the engine's history so I'm definitely going to be splitting the case. At that point you might as well do a 71mm crank and 2.0L rods. Will definitely need to address the heads, FAT/Rimco has several options that refurbish the 1.7L heads but I would like to hear from anyone that has gone that route. I think the 42x36mm valves are bigger than the stock 1.7L valves? https://fatperformance-rimco.com/collection...-heads-exchange https://fatperformance-rimco.com/collection...-heads-exchange I had my 2L case line bored by John Slack in Olympia Wa. He purchased the new main bearings and did the new bores specifically around the size of these bearings. He also fly cut the cylinder base spigots, and had my crank re-ground to first undersize and did the conversion for tapped oil gallery plugs. He rebuilds Rolls Royce aircraft engines and I was very impressed with his tooling. He goes by "Jesco Reient" here Great, I'll try getting in touch with him. Would be great to work with a member here. |
BeatNavy |
Feb 27 2020, 06:13 AM
This is really good read. Seems like you already know most of this, but Jake puts it all in one place well organized: http://www.914world.com/bbs2/index.php?s=&...t&p=1529209
I bought a machined (align bored, decked) case from Jesco a couple of years ago (it then went to Michigan and McMark turned it into a 2258. It's on my garage floor waiting to go into my car when spring comes (IMG:style_emoticons/default/smile.gif) ). His machining skills appear to be epic, and he seemed like a really good guy in the few interactions I had with him. He's not that active here, but you can PM him I'm sure. I built a 2056 from a 1.7L last year. I didn't go "exotic," but I also didn't cut any corners. I spent over $5K in parts and services, including (biggest ticket items): 1. Brand new 2.0 AA (ceramic coated) heads built by Len Hoffman: $1700 2. Raby 9950 Cam kit: $950 3. P&C: roughly $500 (my records are screwed up here because I swapped from valve relief JE to flat top KB at the end, and I don't seem to have cost on the KB pistons) 4. 2.0 H beam connection rods: $300 5. 71mm crankshaft $300 6. New pushrod tubes: $100 7. Case machining, flywheel resurfacing, parts balancing, etc. $400 8. Rocker machining and miscellaneous tools, shims, etc.: $250 etc. etc. You can definitely do it way cheaper, and I know you're on a budget, but I am curious as to what is reasonable economical rebuild (obviously depends on what you can reuse). When I did this rebuild my thought process was "don't skimp ANYWHERE." Right now I've got a 2 liter on an engine stand partially torn down. I'm toying with trying to do an economical rebuild on it, just for fun. My thought process on this one would be "I don't want to spend $5K on an engine I don't need." |
sreyemj |
Feb 27 2020, 06:25 AM
1. Brand new 2.0 AA (ceramic coated) heads built by Len Hoffman: $1700 Good info, I've read that thread and it's definitely helpful. Are the $1700 Hoffman heads actually available somewhere? I thought they were over 3k now. It's definitely easier to do a build for 5k, but that's really pushing it for my budget. |
BeatNavy |
Feb 27 2020, 06:44 AM
I went back and found my HAM invoice, and it's actually:
1. AAP 2.0 914 heads, 44mm x 38mm valves, $1425. 2. Ceramic coating ports and combustion chambers: $225 It sure appears my total was $1650 (with Len supplying the heads), but I agree it's worth verifying. If you have questions reach out to Len and ask him for his help. He's very helpful and a tremendously nice guy as well. |
BeatNavy |
Feb 27 2020, 06:48 AM
I just checked Len's website: https://newsite.hamheads.com/2017/07/01/aa-...9144-knockoffs/
I'm not sure they're making these anymore, but as of January Len had a couple pair still available. |
rbzymek |
Feb 27 2020, 09:21 AM
Member Group: Members Posts: 195 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest |
sreyemj, You may want to consider a 2056 SCAT long block for about $3600. I replaced my worn out 1.8 last year and I am pleased with the result. If you are short on time it will get back on the road sooner. |
Bleyseng |
Feb 27 2020, 12:26 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
This is really good read. Seems like you already know most of this, but Jake puts it all in one place well organized: http://www.914world.com/bbs2/index.php?s=&...t&p=1529209 I bought a machined (align bored, decked) case from Jesco a couple of years ago (it then went to Michigan and McMark turned it into a 2258. It's on my garage floor waiting to go into my car when spring comes (IMG:style_emoticons/default/smile.gif) ). His machining skills appear to be epic, and he seemed like a really good guy in the few interactions I had with him. He's not that active here, but you can PM him I'm sure. I built a 2056 from a 1.7L last year. I didn't go "exotic," but I also didn't cut any corners. I spent over $5K in parts and services, including (biggest ticket items): 1. Brand new 2.0 AA (ceramic coated) heads built by Len Hoffman: $1700 2. Raby 9950 Cam kit: $950 3. P&C: roughly $500 (my records are screwed up here because I swapped from valve relief JE to flat top KB at the end, and I don't seem to have cost on the KB pistons) 4. 2.0 H beam connection rods: $300 5. 71mm crankshaft $300 6. New pushrod tubes: $100 7. Case machining, flywheel resurfacing, parts balancing, etc. $400 8. Rocker machining and miscellaneous tools, shims, etc.: $250 etc. etc. You can definitely do it way cheaper, and I know you're on a budget, but I am curious as to what is reasonable economical rebuild (obviously depends on what you can reuse). When I did this rebuild my thought process was "don't skimp ANYWHERE." Right now I've got a 2 liter on an engine stand partially torn down. I'm toying with trying to do an economical rebuild on it, just for fun. My thought process on this one would be "I don't want to spend $5K on an engine I don't need." This is exactly the way I would recommend going too. Have the case checked first before having it line bored as most 914 1.7l cases don't need it. There are lots of good used 2.0L rods around as buses used them too. Len's heads are top notch and the way to go. (I have them) |
914_teener |
Feb 27 2020, 03:35 PM
914 Guru Group: Members Posts: 5,201 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
What induction will you be using?
The stock FI 1.7 won't be enough for the 2056. |
sreyemj |
Feb 27 2020, 08:38 PM
I just checked Len's website: https://newsite.hamheads.com/2017/07/01/aa-...9144-knockoffs/ I'm not sure they're making these anymore, but as of January Len had a couple pair still available. Thanks, talked to Len this afternoon and purchased a pair. Price was the same as yours, sounds like he has one more set available. What induction will you be using? The stock FI 1.7 won't be enough for the 2056. I thought D-jet could be used with a 2056? I'm debating a set of duel Weber 40s or the Dub Shop megasquirt setup (local to me in Washington State). The MS setup seems like an excellent system, but I really need to find out how much the rest of the engine will cost before deciding if the Dub Shop kit is an option. I had also thought about using the D-jet for now (and installing a FI cam) and then adding megasquirt later after I saved some more money. I need to let Len know what compression ratio and cam I will be using before he can finish the heads, so any suggestions for cam FI or carburated cam choices are appreciated. |
mepstein |
Feb 27 2020, 08:42 PM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I just checked Len's website: https://newsite.hamheads.com/2017/07/01/aa-...9144-knockoffs/ I'm not sure they're making these anymore, but as of January Len had a couple pair still available. Thanks, talked to Len this afternoon and purchased a pair. Price was the same as yours, sounds like he has one more set available. What induction will you be using? The stock FI 1.7 won't be enough for the 2056. I thought D-jet could be used with a 2056? I'm debating a set of duel Weber 40s or the Dub Shop megasquirt setup (local to me in Washington State). The MS setup seems like an excellent system, but I really need to find out how much the rest of the engine will cost before deciding if the Dub Shop kit is an option. I had also thought about using the D-jet for now (and installing a FI cam) and then adding megasquirt later after I saved some more money. I need to let Len know what compression ratio and cam I will be using before he can finish the heads, so any suggestions for cam FI or carburated cam choices are appreciated. I would ask Len (about the cam). He know type 4 engines better than most. |
BeatNavy |
Feb 27 2020, 08:45 PM
Sweet, glad you got in contact with Len.
You can use D-Jet for 2056, but you need to use those D-Jet components specific to the 2.0 (versus the 1.7). Some components work for both, but many of them are specific to either 1.7 or 2.0. Then you need to be prepared to tune the MPS slightly to handle increased displacement. Many here have done it, but you just need to be aware of the requirement. Yes, you can use an FI-compatible cam and change out induction systems later (like going to MS or something else). (IMG:style_emoticons/default/beerchug.gif) |
914_teener |
Feb 27 2020, 09:18 PM
Sweet, glad you got in contact with Len. You can use D-Jet for 2056, but you need to use those D-Jet components specific to the 2.0 (versus the 1.7). Some components work for both, but many of them are specific to either 1.7 or 2.0. Then you need to be prepared to tune the MPS slightly to handle increased displacement. Many here have done it, but you just need to be aware of the requirement. Yes, you can use an FI-compatible cam and change out induction systems later (like going to MS or something else). (IMG:style_emoticons/default/beerchug.gif) What Rob said. Figure ablut 1k for a 2.0 setup all said and done. |
Bleyseng |
Feb 27 2020, 09:40 PM
You need to figure out what HP you want. 2056 w/stock FI cam=95hp. 2056 w/Raby 9950 cam =120hp , both with Djet FI
sreyemj |
Feb 27 2020, 11:00 PM
What Rob said. Figure ablut 1k for a 2.0 setup all said and done. I didn't realize the 2.0 setup was so different from the 1.7L, if it ends of costing 1k to retain the D-jet than I'll definitely be doing something else. You need to figure out what HP you want. 2056 w/stock FI cam=95hp. 2056 w/Raby 9950 cam =120hp , both with Djet FI I'm hoping for around 120HP, seems to be a great level for the car. |
Bleyseng |
Feb 28 2020, 09:40 AM
Where are you in Washington as I am in Seattle. We could meet up so you can drive my car to see how you like the 120 hp setup.
Lo-Fi Version | Time is now: 1st June 2024 - 02:19 PM |
