xsurfer |
Member ![]() ![]() Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 ![]() |
I have a 71 factory six that I had to remove the fuel pump from.
I didn't label the supply and return lines. I am now confused needing a way to identify the return line. Does anyone know if the return line pours into the tank or is it at t the level of the bottom of the tank. Thanks |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,935 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
I have a 71 factory six that I had to remove the fuel pump from. I didn't label the supply and return lines. I am now confused needing a way to identify the return line. Does anyone know if the return line pours into the tank or is it at t the level of the bottom of the tank. Thanks They are two different sizes. The larger one is the supply line. It is to the right of the return line in the tunnel. |
xsurfer |
I have a 71 factory six that I had to remove the fuel pump from. I didn't label the supply and return lines. I am now confused needing a way to identify the return line. Does anyone know if the return line pours into the tank or is it at t the level of the bottom of the tank. Thanks They are two different sizes. The larger one is the supply line. It is to the right of the return line in the tunnel. Outstanding ..........Thank You |
gms |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest ![]() ![]() |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
return line is on the drivers side coming out of the firewall
I have a 71 factory six that I had to remove the fuel pump from. I didn't label the supply and return lines. I am now confused needing a way to identify the return line. Does anyone know if the return line pours into the tank or is it at t the level of the bottom of the tank. Thanks |
Lo-Fi Version | Time is now: 13th June 2024 - 01:32 AM |
